I have C16 RAM which I run at C14 with tight timings, lots of optimization required and on Ryzen/TR memory performance is important. you can gain a decent uplift in gaming frame rate from memory tweaks vs default out of the box performance.
So I would try to get lower latency as you can afford but all make sure the RAM is on motherboard QVL as Ryzen is a fussy bugger.
An old article here but still relevant
https://community.amd.com/community...emory-oc-showdown-frequency-vs-memory-timings
Thanks. Really useful article. Looks worth a bit of tinkering.
At OCUK the cheapest C16 seems to be £149.99 and the 8 pack C14 as mentioned above is £199.99, for 16GB, so £100 difference if going with 32GB which is a decent amount more I suppose.....but.....
I went with the Prime board £289.99. I didn't apply the same logic when buying that as I knew I wouldn't be bothered with overclocking and therefore couldn't justify £519.99 for the top end Asus board. Been very happy with the Prime. Stable, memory all worked fine from day one.
I do like Asus boards, so choice was one or the other only.
Yes I don't think I'll run a 24/7 overclock as the AMD automatic boost seems pretty good. I'll probably do a bit more playing around with the memory. Just need to decide which motherboard, after a solid stable board with quality components and plenty of potential for future upgrades including a 16C 7nm TR eventually.
