Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Put some engine oil in. Light came on 100miles from home at 11pm luckily the Shell garage I just went by had the grade that I needed.
How long ago have you had it serviced? What grade of oil are you using? Can you see any leaks at all?
Replaced the radiator, expansion tank, water pump, thermostat, oil filter housing seal and gave it an oil service.
Classic e46 stuff really.
That couldn't sound any more sketchy![]()
February? I've always put in 0w30, and in the service that's what they put in too and I did the same last year around the 6 month mark between service, a little top up.
You have the same lump as the focus st 225 right? If there are no leaks, possibly try 5w-30 if you're not tuned.
I say this because on 0w-40 my car was burning quite a bit. This is focus rs recommended spec oil. There were no leaks etc. I know when my car was on 5w30 it didn't use a drop.
I've moved over to 5w-40w fuchs titan race pro s and no oil lost what so ever. Maybe you could try 5w30 next service. I feel it shouldn't be burning oil. Especially if you're standard.
I’d expect you’ll get close to that given mine fetched what it did with a knackered gearbox and engine, whilst granted it was a Sport model the wheels weren’t in great condition nor were they the desirable M-Par’s either and the bodywork was crumbling in all the usual e39 places so basically it’s value was the interior - which was very good overall - and little else.
Yours running well with some history and a verifiable mileage will stand out to somebody wanting either a project or an engine donor car...
Be sure to post what you eventually get for it.
Rolled the rear arches, fitted wheels to the rear, removed some of the front bumper support to stop the wheels rubbing, fixed the drivers door lock, fitted a mirror, diagnosed why the blower motor wasn't working (corroded fuse contacts), failed to fix the horn, (it sounds like Olivers horn from Top Gear)
Got underneath it, still shocked at how solid it is.. I think it has the original exhaust...
Needs camber and height fiddling with but no rubs.![]()
It's best not to ask.Why does it need camber etc?
Shut up Grandad.![]()
