- 30 Aug 2018
No need to apologise.Yes sorry, half asleep this morning.![]()
Tyvm for sharing those numbers with us. Get some coffee in you
I'm in meetings all day from 11, always loads of coffee there to keep us all awake.No need to apologise.
Tyvm for sharing those numbers with us. Get some coffee in you![]()
And meetings to put you to sleep. All things in balanceI'm in meetings all day from 11, always loads of coffee there to keep us all awake.![]()
Ah, got you. I’ll pick my jaw up now.![]()
Hmm .. received my Inno3D GeForce RTX 2080 Ti X2 OC last week. Stock with no manual OC or anything daft.
Works fine until I stress it. Default fan profile gets it up to 84c ... manually setting fans to max (too bleeding noisy), drops to 64c or so. But .. keeps crashing
https://photos.app.goo.gl/EvQ4Y4HUDHrpYi876
https://photos.app.goo.gl/DjxdVqr2KX7pLWe37
Usually crashes whole PC but when it does not, these are the recorded temps
Brand new build - never had any other card or Windows on until now.
This was the build ... RMA time?
Intel Core i9 9900K, Aorus Z390 Master, Aorus 16GB RGB RAM **FREE 512GB SSD**
Intel Core i9-9900K 3.6GHz (Coffee Lake) Socket LGA1151 Processor - OEM
Gigabyte Z390 Aorus Master Intel Z390 (Socket 1151) DDR4 ATX Motherboard
Gigabyte Aorus RGB 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual/Quad Channel Kit
Seasonic Focus Plus 850W 80 Plus Gold Modular Power Supply
be quiet! Silent Base 601 Midi-Tower Case - Orange Window
Inno3D GeForce RTX 2080 Ti X2 OC 11264MB GDDR6 PCI-Express Graphics Card
NZXT Kraken X62 AIO Water Cooling Unit - 280mm
WD Black 1TB M.2 2280 NVMe Solid State Drive (WDS100T2X0C)
Seagate 2TB FireCuda 2.5" 5400RPM SSHD Internal Hard Drive PC and PS4 (ST2000LX001)
I find you need decent cooler on your 2080 ti to get the best out of it. Was surprised my gigabyte gaming oc with 3 fans and 2 and a half slot needed 80% fan speed.
*snip*
der8auer says his RMA rate of the 2080ti is 1.4% (he works for Caseking):
Its a featureCoD:Black Ops 4 just now got some flashing black. FE here.
Be happy for it to just stay alive for more than 10 mins
Sounds like some thermal issues here. These cards, for normal gaming, should be plug and play. I'm not a novice builder but if I need custom cooling rig then the card design is messed. Ho hum![]()
Played some more, not happened again, it was as I was exiting a level so it could be a CoD issue but I'm suspicious. I'm on default settings at the moment because no need to overclock really so slightly worrying if the card is crapping out on default settings in a cool case.
My defunct FE didn't initially crash or artifact on benchmarks, only games. I don't think the benchmarks utilize nearly as much VRAM as something like BF1. Once it starts to go though, it'll crash or artifact on everything, including the desktop.Just run something like the Valley benchmark for a while, that should indicate if there's any problems.
Haha true! It is going back though for coil whine, which I guess is a small problem compared with what some people have!
Fwiw I couldn't stand noise of the fans either so going with the EVGA FTW3 Hybrid 1080 ti as my stop gap until 3080 ti now. The rest of my build is silent, it really just stands out.
My FE is the same. Probably the loudest thing in the system is the whine/buzz. But it isn’t heard over my rad fans and speakers.
Same with every 1080Ti I’ve had which is probably 10+ I’ve tested. All different brands and boards. Some are worse than others but never eliminated. Just a norm really for such a power hungry card.
I don’t think it’s so much the coils. I think it’s more the mosfets buzzing away. Minimal at 60hz but at 165hz it’s quite audible next to the case.
