- 26 Sep 2013
- West End, Southampton
To be fair your 8700k at 5.0ghz is probably helping that...
yep no doubt.
Eh?
Wasn't that last month?
No the frostbite engine is terrible when using DX12.
Swap over to DX11 and report back - expect you to feel a massive difference.
.Some are reporting Dx12 to be working much better now.. That should be interesting, if true.
After patch, driver and windows update?
Enjoy 30FPS with RTX on![]()
Does RTX work with SLI, aka DX12 Explicit Multi-GPU?2080 1080p
streamer showcase framerates goes 60-100
seems you need a 2080ti for 1440p and sli for 4k using rtx.
2080 1080p
better than expectedSo - how is RT performing!?
.Having survived an excruciatingly slow patch update, we are testing "Battlefield V" with DirectX Ray-tracing and NVIDIA RTX enabled, across the GeForce RTX 2070, RTX 2080, and RTX 2080 Ti, augmenting the RTX-on test data to our Battlefield V Performance Analysis article. We began testing with a GeForce RTX 2080 Ti graphics card with GeForce 416.94 WHQL drivers on Windows 10 1809. Our initial test results are shocking. With RTX enabled in the "ultra" setting, frame-rates dropped by close to 50% at 1080p.
"Darn you!! I would have completely obliterated you if I was not running Ray-tracing you noob!!" would probably become a new meme/excuse being popularise on BF5 multiplayerits prettier now at half the fps
in a fps shooter game![]()
Well, the 4K owners often talk about not minding to change(lower) settings. RT On and ultra low settings may be the way forward, even at 1080Pits prettier now at half the fps
.2080 1080p
