Poll: Will you be buying a Radeon VII?
  • Total voters
    352
15 Jun 2005
Edinburgh
I seen somewhere that the approved models automatically enabled it, the unapproved ones either had issues with flickering, strobing or didn't enable it automatically?
Yes, the approved ones (currently a short list) get it enabled by default. For the non-approved ones you have to enable it manually. To be Nvidia approved, monitors have to support a min-max refresh range of 2.4X. So all FreeSync monitors with a narrow refresh range are automatically classed as non-approved. AMD now requires a similar 2.5X range for FreeSync 2 monitors.
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Nope. It is basically around the same performance as what I already have plus 4GB extra RAM which will never be used. If it was £500 then it would have made headlines and everyone would have been singing its praises, but it is just too expensive.
Man of Honour
21 May 2012
Dalek flagship
This is the silliest thing about the memory on the Radeon VII, the bandwidth.
Below is a pic of the memory bandwidth on the RTX Titan overclocked very high and it is nowhere near the figure claimed for the new AMD card, are they really saying it needs that much compared to a much faster NVidia card.
There was a time when AMD delivered exactly what gamers needed.
Caporegime
18 Oct 2002
Ireland
Which is a farce that they implemented just to inflate their numbers, how is the panel not enabling it by default considered to be a failure? Turning on a toggle in the control panel is such a hard thing to do?
Permabanned
2 Sep 2017
This (6912 GFlops/s):
Or that (510 GFlops/s):
Caporegime
18 Oct 2002
No, AMD never intended to give a consumer gaming card that much bandwidth. It all comes back to the fact that it is a salvaged part from failed Instinct Mi60 GPUs. Once the 4 stacks of HBM2 are mounted to the interpose you can't remove them. Therefore you get 16GB VRM with 1TB/S bandwidth, of the whole lot goes in the bin.
If AMD wanted to have a dedicated gaming part they would have stuck to 2 stacks of HBM for 8GB and 512GB/s
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Was about to reply to him, but it seems you did it for me. Basically this.
It is not made from the ground up for gamers. No need to be confused :)
AMD trying to be relevant in the gfx arena
Rad 7 is a silly card with silly memory for silly money
:p
It might end up only being £50 more than what you paid for your 1080 Ti in the end easy, if it performs the same then it will be funny as you are calling this silly, but you went on about your £600 purchase of a 1080 Ti like it was the best deal ever. Lol.
19 Feb 2007
ArcCorp
Nope not buying, The R7 only has 3840 stream processors and the full card has 4096 so they'll probably release a R7+ i.e the full fat thing, 6 months after, Then I'll buy it.
Just a suspicion.
