But the point of the comparison is to outline the difference % between the two products in which case the absolute numbers that are being compared are not relevant. In which case, it makes no sense to use the competitor's product.
The problem AMD have is if they had use an AMD CPU some idiots would have said "Well it's CPU limited! If you had a better CPU the 2080 might pull ahead".
