The glow/bleed is still very visisble even on low brightness, not as much of course but very visible.
And thanks for the reference. That is indeed a good one you have there.
Maybe I try again when this monitor drops in price.I see two people mentioning a brightness of 17 and 15.
Is this out of 100.
Are you guys living in pitch black darkness or is this the norm to set the screen brightness so low ? My monitor is currently on 50. Stock was set to 70.
It has smudges and blotches all of the screen.
@Daniel - LG you need to take note of the above issue, a bad reputation for QC is easy to get and hard to shake! That is totally awful @Thermo and would really put me off buying a new LG![]()
If they're on top of the screen, they look like they might come off with alcohol. Too late now, of course.
I just received this monitor and am shocked at the condition it came in. This was originally sealed and did not look like it was used. It has smudges and blotches all of the screen. The blotches or spots will not come off. I can see these when I shine a light in front of the screen. This is clearly a quality control issue. See the photos below. Does anyone that owns this monitor have any of these visible?
I contacted LG and they want me to send it in so they can determine if this is a defect. Unbelievable! I have never owned a new monitor that came in this condition. I'm just sending it back for a replacement to the place I purchased it at.
http://i68.tinypic.com/1688sye.jpg
http://i67.tinypic.com/2h3pjxk.jpg
I had the exact same issue, including 2 scratches.
Did you exchange the monitor and if so was the new one ok?
Where did you purchase the monitor?
@Stu Did you go with one of these in the end?
Why is there so few of these around ? Are they only manufacturing 1 of them per day on the whole of the planet ?
Been wondering same, is there some major manufacturing issue with yields of panel resulting in a lots of panels being thrown to bin at the factory?
Well monitor arrived yesterday and while there was a massive gash in the side of the box the contents seem ok. Screen looks great, no dead pixels that I can see, and back light bleed no worse than on my previous AW3418DW.
Does anyone else have a similar issue to below? When mounted in the stand the monitor is (via super scientific lego measurements) approx. 5mm higher on one side to the other. My desk is level so not sure what causes it. However there does seem to be quite a lot of movement where the stand clips in to the VESA mount of the screen.
@Daniel - LG / @anyone else with 34GK950, thoughts appreciated..
