Panos,
I read up to the point you decided to mod the cooler on the Gigabyte reference card but didn't see anything negative in your comments about it with temps, scores or noise. You mentioned it was actually quieter than your other Nitro Vega. I wasn't sure in your above post if you were agreeing that Gigabyte is worse but it seems like you had a good experience with it.
Are you still using both? Is the Nitro performing better/more stable than the Gigabyte in you opinion? I'm using some of your recent Wattman settings recommendations on my Gigabyte OC version with good results. Thanks!
Where I said modded Gigabyte reference cooler? My reference card is Sapphire, the one with the blower, not the dual fan Gigabyte one.
Few days later when had the waterblock, used liquid metal to just run some test concluding that it doesn't worth. Reason is less heat allowed bit more clocks but raised fan speed.
Noise was obvious more loud card than the Nitro, from this post
Actually coil buzz is less than the Nitro, however even if you try to listen to it, the jet engine in there covers everything
but true had lower coil whine to Nitro, and almost non existent these days.
I use the, on air, Nitro on the workstation upstairs, and the reference is watercooled.
