- 26 Sep 2017
- In the Masonic Temple
I class that as a "setting" and maxing it would be 200%, no ?This^
With everything maxed and Image quality @100% using 2160p memory was just under 6gb.
With the above settings but with image quality @200% which I think is the same as running the game @8k memory is 14.5gb.
I don't think anyone is going to want to run the game with 200%(8k) image quality as the fps are a bit low.
Freedom for the user to increase his/her render resolution without buying another monitor if you have the power to do so.
