Thanks very much, I'll report back once I've done.
No its a graphics setting, im saying that if you say 4k maxed, and theres a setting that isnt at its maximum its not maxed but forget it anyway, stupid argument im sorry@Illuminist
So basically you saying this.
What is the highest resolution you can buy now 8k? I game at 1440p on PC so what you saying I can never max out any off my games! Because I can not render at the highest resolution available. My VEGA 64 most defo can not do 8k playable so I might has well give up now I cant max out games on PC!
LOL
You sir are funny.
Just realised i forgot to show the settings used in the 4k video, but they were same as the 3440x1440 video in which i do show the settings, except the resolution was increased to 4K.
Image quality was at 100%, no point trying to render the game at 8K as the FPS would be unplayable.
Thanks for the info Kaap.Maxed out @200% on an overclocked RTX Titan.
2019-01-18 09:47:11 - re2
Frames: 4590 - Time: 170109ms - Avg: 26.983 - Min: 22 - Max: 33
Image quality is actually a lot worse than 100% as I don't think the other graphics options work properly @200%.
Even if the game devs get mGPU working to increase the fps it won't make the image quality any better.
If I was playing this game I would have Image quality set to 100% regardless of what hardware it was running on.
Thank you for that Kaapstad,Maxed out @200% on an overclocked RTX Titan.
All good?
I just used it to freeze the time after i had received my achievements, it didnt mess with anything, i freely explored and finished the demo on my own time and then deleted both the demo and the thingHi, I read you have to mess around with the achievements as well and don't want to do anything that might affect my overallaverage, but it's mainly because I also heard your account can get flagged for doing so some time ago.
How did you get on?
. Had to reset windows as I’ve disabled system restore. 1hr later the new AMD driver was installed.Well another EVGA PSU to add to the pile. A friend got a Vega64 LC edition and after popping into his PC, his PSU just **** the bed and died hard. Turns out it was one of the Superflower ones that just don't do Vega. He's got an 850W Corsair now and running great on the same hardware![]()
So I had an early chance to do a little tinkering.
1st of all I downloaded the latest DDu uninstaller and the new 19.1.1 Drivers.
Once the GPu driver was removed I did a restart and windows 10 got stuck in a boot loop,. Had to reset windows as I’ve disabled system restore. 1hr later the new AMD driver was installed.
My LC seems to be ok at stock settings with HBM at 1100mhz. Had a good run on subnautica with no crashes.
Then I dialled in your screen shot settings. She didn’t like it.
Have left it at P6 1667 (1120mv)
P7 1752 (1220mv) with HBM at 1100mhz for now, happy with temps.
Seemed to hold at 52-58c for longer and the fan doesn’t ramp up as quick.
Going to Dl the Resi 2 demo later and try her out with that.
Will have another go at it and hopefully squeeze some more.
Thanks.
No my friend, I finished the demo, got the 5 10 15 20 25 30 minute achievements or whatever increments they were, then got the thingy we are talking about, ran it, ran the game and my timer was back to 30 but frozen on it so it never went down.After the game had locked you out?
I'm presuming I can't freeze time as I reached the time limit and when I Googled how to do it, it said I needed to reset the timer & the achievements.
Message me on trust on here and i will give you my steam name, we can sort it out from there easy peasyAfter the game had locked you out?
Do you overclock the CPU?
I overlooked this message but no, so the XMP is enabled but everything else is unchanged. Should I really **** about with voltage if it should be stable as is, or is it nothing to worry about if I under/overvolt in small increments?
Also wouldn't memtest86+ be better as I don't have to run it on Windows?
Was XMP always enabled?
Well this is concerning as I have a 650 P2. Hasn't blown up though. ¯\_(ツ)_/¯Well another EVGA PSU to add to the pile. A friend got a Vega64 LC edition and after popping into his PC, his PSU just **** the bed and died hard. Turns out it was one of the Superflower ones that just don't do Vega. He's got an 850W Corsair now and running great on the same hardware![]()
