As I posted in another thread, I've been having a problem undervolting my reference Vega 64 (air).
If I first reset all the settings in Wattman, then start with a clean undervolt I can get my card stable with all states from p1 to p7 at 950mv. I can have Heaven running for a long time and HWinfo or GPU-Z shows GPU VDDC as 950mv, and the GPU Chip power is around 170W. The clocks will remain steady around ~1500mhz give or take a little. I leave HBM as is at 945mhz.
After exiting Heaven (or whatever game or benchmark I ran first) then try another benchmark or game then suddenly the GPU VDDC gets stuck at either 1050mv or 1100mv and the power consumption goes up to about 230 or 240W on average.
If I try changing voltages or clock speeds in Wattman or OverdriveNTool nothing effects that VDDC and it just stays at either 1050mv or 1100mv. Even resetting Wattman to defaults at that point doesn't do anything and the VDDC value stays the same. Reboots or shut downs don't do anything either and it's only until I force the card to crash by setting some really high clock that everything goes back to default.
Does anyone know what could be causing this, and if there is a way to prevent the core voltage (VDDC) getting stuck at a certain value?
