Potentially, I think for now since I can't actually see it unless I peer over KB, it's not a worry.
Just never move the keyboard and you'll be fine!![]()
I can move the keyboard quite a bit, just not towards the hole for obvious reasons
10/10 triggered that your keyboard isn't centred to the monitor @LiE
The drill came out, the mouse pad was dropped for now. Setup has almost reached power level 9000.
Muuchhh better
My god the difference now the cable is gone
This is like happy brithdays all over again!
As someone who needs things just so I’m now a bit conflicted as I know it now looks great but I also now know there’s a random hole in that pristine desktop whether I can see it or not.![]()
It is a big improvement definitely.
Next on my list is to refit my LED light strip at the back edge of the desk and buy a Logitech MX Master 2S as my daily. The G703 is really good for games but the battery only lasts 2 days.
I do plan to sand it a little and tidy it up, but honestly you have to go out of your way to see the hole.
Some things:
1.) How have you not killed your desk surface using a mouse with no mat?
2.) Next upgrade should be that chair
3.) Nice hairdryer.
Yeah... I spotted that too. @kona786 do you dry your hair at your desk?
So good I bought 2, one for the home office and one for work so both mice are set up the same way. Love it. Charging time is minimal for the life you get out of the mouse.You won't regret the master 2S. Awesome mouse.
