Pic: Your desk...RIGHT NOW
The drill came out, the mouse pad was dropped for now. Setup has almost reached power level 9000.
So good :)
I also really want that glass :D
As someone who needs things just so I’m now a bit conflicted as I know it now looks great but I also now know there’s a random hole in that pristine desktop whether I can see it or not. :D:o
Muuchhh better :D
My god the difference now the cable is gone :D
This is like happy brithdays all over again!
It is a big improvement definitely.
Next on my list is to refit my LED light strip at the back edge of the desk and buy a Logitech MX Master 2S as my daily. The G703 is really good for games but the battery only lasts 2 days.
I do plan to sand it a little and tidy it up, but honestly you have to go out of your way to see the hole.
Just get a G603. Same form factor as you G703 but the batteries last forever - unless you're too anal about the weight of AA.
Also, better find a mousepad soon. Otherwise the mouse will start to wear the surface of your desk.
Turn off the RGB lighting and it will last a lot longer.
Some things:
1.) How have you not killed your desk surface using a mouse with no mat?
2.) Next upgrade should be that chair
3.) Nice hairdryer.
1. Ha, must be a good quality desk. I haven't had a mouse mat since the 90s.
2. It's a lot comfier than it looks. Plus I like the look of it. Usually has a cushion for long stints.
3. The easter egg. Well done.
Yeah... I spotted that too. @kona786 do you dry your hair at your desk?
It's for the wind in the hair effect in games. :D
new desk - waiting for the matching filing cabinet to go with it. Just need to work out a better monitor stand solution, will be putting a window behind it next year so wall mounting isn't really an option.
