- 1 May 2013
- M28
BetterJust done a 30 min back to back play test on Beat Sabre between the Quest and the Rift (CV1) and I actually think the Quest version is better. The improved resolution on the Quest is really noticeable when swapping back and forth.
I got a pair of Diono Soft Wraps Car Seat Strap Covers today.
https://images.app.goo.gl/7gbQQJCaMpVoQzCM7
One of these fits very neatly onto the rear strap of the Quest and makes it way, way more comfortable for me, and more secure.
As you get two you can also use one for the top head strap if you want. You can get grey and black,but For some reason I got sent one of each, but I found the grey one to be softer and more comfortable.
Edit: Turns out I had the grey one inside out, so it looks like they're reversible. I find the grey side more comfy.
Only costs £5.95.
Amazing how much difference a small bit of padding can make.
Where from? Got pics?
