It was Hardware Cannucks. He said he was talking to MSI and they said "Overclocking capability has improved drastically" - SAUCE - https://youtu.be/nZyMdUFHzZY?t=216
I'm not sure why people are moaning about the motherboard prices, unless you're wanting to utilize PCIE 4.0 or do extreme overclocking on the 12C/16C variants then use the current gen.
You can grab a MSI B450 TOMAHAWK for like £90 or so.
Pick something decent from the AM4 B450/X470 Motherboard VRM Tier List and you're good to go:
https://docs.google.com/spreadsheet...MvYeCLI5ZbIpnq5fyiWD4NCkkU/edit#gid=229691480
For people going 6 or 8 core the TOMAHAWK would be a perfectly good board, i might just do that myself if there isn't a decent B550 board avalable for around £100, like the TOMAHAWK always was, i think the most expensive i have ever seen it was £110, its almost always been a £99 or less board and a good'n.
Yep, I'd expect the VRM setups to be better across the board on B550 purely to deal with the higher end Ryzen chips.
If there's no B550 at launch I'll probably go for the X470 Pro Carbon AC or similar paired with an 3800X, first AMD chip since Athlon 64![]()
So I heard that the old x370 boards might get a BIOS for the new chips.
Any ideas what the (poor) VRMs on the x370 gaming 5 gigabyte board might be up to? Could it run one of the 8C chips?
Is there an expectation that these will over clock to do all core performance at the 4.5/4.6 boost levels advertised like the Intel stuff does?
Could be a cracking cheap upgrade...
Your board tops out at "only" 240A vcore delivery @54w (ish) heat and with lower switching frequency as the top dogs, but should certainly be fine for the current release line up, providing of course Gigabyte are supporting Zen 2 on this board.
Apparently there won't be B550 until next year, and it might not even be PCIe4, only 3 to keep the cost down.
So a 9900K is 50% faster but a 8700K is 3x faster?
Do you read what you type?
Surely B550 will still have PCIe 4 off the CPU? Just, presumably, not on the PCH if there's cost savings happening.Apparently there won't be B550 until next year, and it might not even be PCIe4, only 3 to keep the cost down.
Then i'm getting a 400 series board, i like @Kashinoda idea tho B450 version, https://www.overclockers.co.uk/msi-...ocket-am4-ddr4-atx-motherboard-mb-33s-ms.html
Its still around for £110 to £120.
I don't understand why they would release the expensive boards and then make you wait what? 8 months till next year for the ones most people can afford, i'm not going to spend £200 just because that's all that's available on the new chipset, no... i'll get an older one.
his cpu vs modern cpu. is two to three times faster. in games that use this well there is massive differences. look at battlefield benchmarks. nearly 100 fps in mp differences sometimes at 1080. in big battles. before the budget crowd dive in thats the same as going for something like a 750ti to a brand new 2080ti jump. at that res.yet people dont want that boost because its not amd. that boost was available 2 years ago. now amd are bringing you that same 8700 intel power at £200 2 years later and people are like wow this is amamzing intel slayer. what ? 2 years ago ! yes on a budget you would have saved £200 over 2years but you would have had 2 years of use every day and i bet the 8700 will still be faster overall in most games for the period of its life time.
remember hes on a 6 year old i5 and saying there is no point in upgrading to intel as theres no difference or worthwhile difference. there is there has been for years. he just didnt want to pay intel price. but over time it works out and you could have been happier for 2 years and still have what you have now.
people often factor in value on purchase . which is wrong. value over time often and performance. should be factored in. people have cpus for normally 3-5 years.
Tell that to my £220 4690K which less than two years after purchasing was superseded by upto 90% extra performance in games with a £160 1'st gen Ryzen.
Tell that to my £220 4690K which two years after purchasing was superseded by upto 90% extra performance in games with a £160 1'st gen Ryzen.
