copied from another thread and posted by @MassiveJimThere was a full price list for MSI boards. Whole range. And they were +£100 on last gen.
Update 29.05.2019 16:44 clock
According to MSI, the prices posted on Monday via press release were incorrect. The final prices should be different, but they can not call the manufacturer. At the request of the manufacturer, the editors have removed the allegedly wrong prices for the time being.
Does it though? Because Ryzen 1000 and 2000 would overclock to the hard limit the same on either a £60 board or a £600 board. It made no difference.
don't think any of us need to get all bent out of shape just yet over motherboard pricing.
yeah. what i mean is that as the 1st and 2nd gen chips were basically at max clocks, even when overclocked that tiny bit, they didn't draw that much more power - maybe 40w extra.I have a feeling 3700x will have room to open up and void its low TDP
good good.copied from another thread and posted by @MassiveJim
overclocking a 4c4t processor, back when tdp actually meant something is totally different to today thoughI've overclocked the hell out of my 4690k on a £70 Z97 PC mate. no issues at all.
This is conjecture, but I'm assuming some £100 boards will clock better than some £500 boards but also that the differences will be marginal either way. Even the cheap X570 boards will have plenty of headroom on power and voltage regulation.true but if you're looking at a 5 series board id imagine you're looking at a 12 or 16 core chip so you'd want the better build on the higher end boards also as i said IF you need the pcie 4 bandwidth also but wait for them reviews to see what difference there is.
if you're running stock and dont need the pcie 4 grab a 4 series board and enjoy the savings. again depends what cpu you're after if the leaked power draws of that 16 core when overclocked is anything to go for a x570 will be a must if the 300 watts leak is true.
which is why any board with half-decent vrms could handle the extra load.
now if ryzen 3000 can go to town on overclocks (we shall see) then maybe it would make sense to invest in a board with decent vrms/cooling if the thermal limit will be breached a la 9900k.
Nobody is ignoring the fact there will be cheaper ones.Yeah seeing a lot of postings around the web about stupidly high board prices and how its terrible ect.. conveniently ignoring that you will be able to get much cheaper ones.
Just going to be down to the reviews to see which are best VFM.
Really ? That would annoy me , I went to town with Hwbot , have to smash the score or I just don't bother submitting.
process node change.I just don't see these new chips overclocking well, AMD haven't left anything in the tank with previous generation Ryzen chips with regards to OC headroom, so why would this change now ?
If they were able to hit (much) higher speeds then surely AMD would have clocked them a little higher already and not just beaten Intel but absolutely smashed them
they do indeed. just need to see reviews nowAgain, by the looks of it most boards have over-specced VRMs that should easily handle high (300W+) CPU power for the 16 core cpus. So long as they're cooled sufficiently, which most seem to be but you never know on the contact by looking at them.
People are annoyed because like for like boards have gone up a ton.
The exact same board from x470 to x570 has gone up a lot. Thats why people are annoyed. Rightfully so. I guess that little chipset fan is costing us £80 lol .
