AMD Zen 2 (Ryzen 3000) - *** NO COMPETITOR HINTING ***
9 Jul 2007
Or get a Ryzen 5 2600 for £120,a B450 Tomahawk for £90,and some 3200MHZ RAM for £100 - that is £310. Last year when everything was more expensive,my Ryzen 5 2600,high end B450 mini-ITX motherboard and 16GB of Samsung B-die RAM,was around £410 to £420 and I upgraded from a Xeon E3 1230 V2/Core i7 3770.
Yup that's my current thinking
19 Feb 2011
We won't have to, but the prices I posted yesterday were from an Italian retailer, to demonstrate that the prices shown by some click bait website were just that, click bait.
Distributors will have loads of stock, and as I mentioned the allocation of parts seems to be un-problematic presently. I am pretty confident that every major UK retailer including OCUk will have stock, and based on that will price them appropriately, due to the value add form securing a motherboard, RAM and possibly cooler sale at the same time, or in some cases entire systems.
I don't think you'll have any issue buying an older generation board, and putting a 3700X - 3900X on them, much to the annoyance of some people who seem to be trying to convince people otherwise. I think the main factor for older boards is ensuring that they are given regular BIOS updates if changes are made along the way.
Yeah im quite fortunate that i have the Zen 1700 i can plop in and use to BIOS update on a board that does not have flashback, tempted to try the 3900x on my CH6 as im only going to be using my G.Skill Trident Z C16 3600mhz Ram, it may work well together nicely, but depending on performance via OC'ing or or PBO etc may mean i need to move to a new motherboard....
Getting closer to official review day i guess :) should know more soon.
19 Apr 2003
Amen.
I've got a couple of builds/upgrades lined up for friends with this in mind - as gut feeling is the same - but they can afford to wait for reviews for assurances in chip choice. But in both cases the 3700X would suffice but suspect the will be beguiled by 3900X stats...
*And thanks again @Journey for that AMD mic leak before official Computex keynote- everything in one little soundbite. So got much needed sleep...
11 Mar 2013
I wonder if someone buys a x470 motherboard would zen 3 work on it? With x570 board seemingly going for stupid money is going x470 the smart choice? You would want a upgrade path, but don't know if x470 would work with future AMD cpu's?
Permabanned
2 Sep 2017
This is the full lneup:
  • Ryzen 9 3950X—16C/32T, 3.5GHz to 4.7GHz, 72MB cache, 105W TDP, $749 (in September)
  • Ryzen 9 3900X—12C/24T, 3.8GHz to 4.6GHz, 70MB cache, 105W TDP, $499
  • Ryzen 7 3800X—8C/16T, 3.9GHz to 4.5GHz, 36MB cache, 105W TDP, $399
  • Ryzen 7 3700X—8C/16T, 3.6GHz to 4.4GHz, 36MB cache, 65W TDP, $329
  • Ryzen 5 3600X—6C/12T, 3.8GHz to 4.4GHz, 35MB cache, 95W TDP, $249
  • Ryzen 5 3600—6C/12T, 3.6GHz to 4.2GHz, 35MB cache, 65W TDP, $199
  • Ryzen 5 3400G—(Zen+) 4C/8T, 3.7GHz to 4.2GHz, 6MB cache, Vega 11 Graphics at 1400MHz, 65W TDP, $149
  • Ryzen 3 3200G—(Zen+) 4C/4T, 3.6GHz to 4.0GHz, 6MB cache, Vega 8 Graphics at 1250MHz, 65W TDP, $99
I think it should have been this instead:
  • Ryzen 9 3960X—16C/32T, 3.5GHz to 4.7GHz, 72MB cache, 105W TDP, $749 (in September)
  • Ryzen 9 3920X—12C/24T, 3.8GHz to 4.6GHz, 70MB cache, 105W TDP, $449
  • Ryzen 9 3900X—12C/24T, 3.7GHz to 4.5GHz, 70MB cache, 95W TDP, $379
  • Ryzen 9 3900—12C/24T, 3.5GHz to 4.4GHz, 70MB cache, 65W TDP, $319
  • Ryzen 7 3800X—8C/16T, 3.9GHz to 4.5GHz, 36MB cache, 105W TDP, $299
  • Ryzen 7 3700X—8C/16T, 3.6GHz to 4.4GHz, 36MB cache, 65W TDP, $269
  • Ryzen 5 3600X—6C/12T, 3.8GHz to 4.4GHz, 35MB cache, 95W TDP, $219
  • Ryzen 5 3600—6C/12T, 3.6GHz to 4.2GHz, 35MB cache, 65W TDP, $179
  • Ryzen 5 3400G—(Zen+) 4C/8T, 3.7GHz to 4.2GHz, 6MB cache, Vega 11 Graphics at 1400MHz, 65W TDP, $129
Caporegime
1 Dec 2010
Welling, London
It’s not clear yet, but zen3 could well be a new socket. AMD said AM4 will last to 2020. They haven’t said if this means the end of AM4 in 2020.
Permabanned
2 Sep 2017
Vermeer aka Zen 3 is AM4. It would be a suicide from AMD if they require from us to ditch the hyper-expensive X570 boards in just 12 months.
Permabanned
2 Sep 2017
Why would you think this??? 12c on desktop no need for most!!!
This is the main excuse by AMD for not offering more 12C SKUs. But I guess they cannot tell us what we need.
I need a 12C because I know that threads are consumed by running applications very easily.
17 Jul 2005
its temping ! very tempting ! know @tamzzy has an eye on it .
wanting to see someone show horn in dual 240 rads in the thing . Case does look good but for 2080/2080ti or vega 7- think to much heat is produced by the GPU for it to handle
I used to run a 240mm Rad in the front of mine until my wife and I switched cases. I found CPU temps to be fine (8700k @ 4.9Ghz) but my 1080TI FE got warmer than I would like even with the blower cooler. The case has no exhausts barring the PSU so hot spots can appear if your front fans don't move enough air (Corsair SP120's in mine).
My wife is now running a R5 2600 @ 3.8ghz all core (stock volts) and a Sapphire Pulse Vega 56 (undervolted and overclocked). With the PSU exhausting and clean air flow from the dual 120mm fans (Corsair AF120's) in the front, the temps aren't too bad.
