AMD Zen 3 (Ryzen 4000) already in the works
OP
12 Feb 2014
Somewhere Only We Know
Will go for the 3900X from a 2700X. Will keep X470 board for a while then might swap over to an X570.
Im more interested in the X570 motherboards than I am RyZen 3000 CPU at the moment, the only thing the CPU would bring me is PCI-e 4.0 and a small speed increase, probably not noticeable in everyday use, same amount of PCI-e lanes from the CPU only it will be PCI-e 3.0 instead, what I really want is 3 nvme drives in RAID0 at full speed, and X570 will do that for me, even with my 2700X.
26 Sep 2010
Stoke-on-Trent
I'd double-check that before pulling the trigger. Part of the reason 3x NVMe RAID is there is because of the PCIe 4 link giving sufficient bandwidth from the CPU to the PCH to actually do it. Is this feature actually available with a PCIe 3 controller in the 2700X?
19 May 2004
A 2700X has 24 PCI-E lanes
16x to the GPU
4x to the M.2
4x to the chipset
All Gen 3.
So maximum non graphics is 8X PCI-E Gen 3 speed.
With a 3000 series processor it's all the same except PCI-E Gen 4 speed.
I'm not sure on the situation Raiding across the CPU connected M.2 slots and chipset M.2.
Caporegime
21 Jun 2006
History tells us you are likely to be wrong.
i just don't see how they can make them more cores. when i'm gaming the game only uses x% of the cpu and nowhere near 100%. that's because it's relying on the cpu to do equations before it can work on the next set. they can't all be done side by side.
sure as games get more complicated they will be split up further. but core speed makes the biggest difference.
right now 4 cores with ultimate clock speed will beat any 8 core cpu. clock speed is king when it comes to gaming not core count.
the gpu does most of the work anyway.
9 Jan 2019
keeping the industry back at quads on high clocks will do nothing but slow progress of engine development.
Plus there is only so far you can go with clock speeds and we have just about reached it now.
Games are a tiny part of the PC landscape, lots of the rest of it does respond better to multicores so its never going back to puny quads again.
13 Jun 2009
Setting aside your very simplistic understanding of software, what games are you talking about? There are plenty of newer ones that are bottlenecked by 4 cores. Sure if those 4 cores were at 10 GHz they might not be bottlenecked but the industry realised 15+ years ago that this isn't a reasonable expectation for silicon.
The older long pipeline designs got to 4 GHz (Pentium 4) many years ago and that was it. The fact that newer chips got to 5 GHz too (Bulldozer, Sandy Bridge/Skylake/Kaby Lake when overclocked, Coffee Lake) is pretty miraculous to be honest.
Permabanned
2 Sep 2017
You have to update your information. Recent games utilise 8 cores at 100%. 4 cores have no chance, except for slideshow, these days.
Caporegime
21 Jun 2006
apex legends, cs:go are the main 2 i play. obviously cs:go is ancient but apex is new.
my point is they should have 16 core cpus at 5ghz and 4 cores at 15ghz so they cover all markets. rather than focusing on more and more cores with same speeds.
i want an improvement in cores speeds not just more cores which are going to sit there doing little.
13 Jun 2009
Maybe you should think to yourself "hmm, why aren't there 4 core 15 GHz CPUs around?".
26 Sep 2010
Stoke-on-Trent
16x to the GPU
4x to the M.2
4x to the chipset
All Gen 3.
Thinking about it now, I don't think my comment was correct.
According to the X570 block diagrams floating around, the chipset can have two M.2 drives attached with 4 lanes each in addition to the single M.2 hooked into the CPU. So right there I'm not sure if you could RAID all 3 drives, likely just the 2 on the PCH. But doesn't that also mean the PCH-CPU connection is only half the bandwidth of M.2 RAID0 (assuming both M.2 drives are PCIe 4 and max out their 4 lanes)?.
OP
12 Feb 2014
I have already checked it out,it would work exactly the same way as it would with a RyZen 3000 cpu, only it will run at Gen3 instead of Gen4, but my nvme drives are Gen3 anyway, so I dont need Gen4, unless I want to spend £1000's changing everything, you still get the same amount of PCI-e lanes etc, only at Gen3 with 2000 series CPU's.
Taken from the MSI website, I noticed ASUS motherboards opted for 8 SATA ports and 2 M.2 slots, which is why I wont be buying ASUS, MSI and Gigabyte went for 6 SATA ports and 3 M.2 Drives:
AMD® X570 Chipset
  • 6x SATA 6Gb/s ports
  • 3x M.2 slots (Key M)1
    • M2_1 slot (from AMD® X570 Chipset) supports PCIe 4.0 x4 (3rd Gen AMD Ryzen™) or 3.0 x4 (2nd Gen AMD Ryzen/ Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics) and SATA 6Gb/s 2242/ 2260/ 2280/ 22110 storage devices
    • M2_2 slot (from AMD® X570 Chipset) supports PCIe 4.0 x4 (3rd Gen AMD Ryzen™) or 3.0 x4 (2nd Gen AMD Ryzen™/ Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics) and SATA 6Gb/s 2242/ 2260/ 2280 storage devices
    • M2_3 slot (from AMD® Processor) supports PCIe 4.0 x4 (3rd Gen AMD Ryzen™) or PCIe 3.0 x4 (2nd Gen AMD Ryzen™/ Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics) 2242/ 2260/ 2280/ 22110 storage devices
Caporegime
21 Jun 2006
because they haven't been able to crack the tech needed to do it yet. i'm sure it will happen one day but the focus seems to be on more cores. rather than more speed.
if we can overclock 3ghz cpu's to 5ghz at home. people like 8 pack are breaking world record speeds all the time then it can be done.
