Finished installation of the Morpheus II today with 2 Noctua NF-F12 Industrial 3000
Installation is tricky with the heatsink been short so some chokes cannot get heatsink on. Installed the long VRM heatsink and used a high temp resistant cable tie to wrap it around.
On normal running Firestrike on Turbo settings with the fans at default 280-450 rpm, temps were 46C core, 50C HBM, 67C Hot Spot and 39C VR MVDD.
I have manually set the fans now to 1053 minimum, because they are damn quiet.
All in all happy with the progress made
I will tweak and OC the card now and see how far can be pushed with this huge heatsink.
Update. Meh. Reference cooler is better, which unfortunately could have used in a jiffy if I had it.
Even if I have the fans on pretty high settings, there is a lot of unmoved warm air between the cooler and the PC. Moved the fans forward to have one covering the bit VRM fully but doesn't help.
Core is cool, so is HBM, cannot say the same for the VRMs heatsinks, which are boiling on anything less than 1400rpm.
