Thanks for link LOOKS GOODPut 3800x @143-145
.Please remember that any mention of competitors, hinting at competitors or offering to provide details of competitors will result in an account suspension. The full rules can be found under the 'Terms and Rules' link in the bottom right corner of your screen. Just don't mention competitors in any way, shape or form and you'll be OK.
.It was also done with a semi-functional BIOS that froze when they tried to change some settings. I'd say this is an absolute worst case scenario for testing, which is pretty promising given how decent the lower-clocked hexa-core is still doing.Please note - that review was done without the most recent amd chipset driver & the latest windows 1903 amd improvements
It froze when trying to do a manual overclock...It was also done with a semi-functional BIOS that froze when they tried to change some settings. I'd say this is an absolute worst case scenario for testing, which is pretty promising given how decent the lower-clocked hexa-core is still doing.
So the 9900k is still the king of gaming according to that
What's your point, caller? If it froze as soon as they touched a basic setting, then it's clearly not a fully functional BIOS designed for this CPU.It froze when trying to do a manual overclock...
No... beyond 8C 16T i don't think there is any scaling, at that its all down to clock speed, Zen 2 has the IPC and i think the 3950X will have the clock speed to beat the 9900K, but not by much.
i think the 3700X will be a close match, the 3800X a definite match.
My only concern is if I can run 4x16GB@3600 memory on a 3900x without having to gimp anything.
If the new windows scheduler made a differnce they would have demo'd that at their keynote.you are not taking into count the extra cache the 12 & 16 core parts have. With the new windows scheduler update this may see a extra boost for these parts over the 8 cores using the single chiplet.
Will be very interesting to see the reviews on launch day. I will be doing a lot of reading before I decided on 8 or 12 cores.
You know best iot will be Motherboard dependent heheWell, with all the Zen2 cpu's you have tested and posted reviews on already, shurely you already know the answer to your own question.
That was a tongue in check answer to the resident forum troll @Zeed lol.The scheduler tweeks might not be massive gains but could be enough to push a tied result to AMDs favour.
All I'm saying is that for the moment until we see those benchmarks we can't say 100% can we?How do you work that out?
With several much faster chips in the product stack to come its a bit premature to be declaring Intel still king of gaming.
Also even if single threaded games come out close to each other the massive multicore advantage that Zen seems to have over intel is enough to swing it - a cpu is not just about how fast one of its cores can run at.
I suspect the 9900 and 3700 will be close (within 3%) of each other in gaming, the 3800 a bit faster (5%) and the 12 /16 core monsters handing the 9900KS its ass when it comes out.
I agree! I was about to drop over 1k on my next upgrade as well!It's not clear, that 3600 was not overclocked either on not updated chooser drivers.
It's going to be very interesting and looks worrying for intel.
Why don't either company isolate a single core for single core related things and let it boost into an inferno?
By isolate i mean totally, there are tasks in games that can't be multithreaded and absolutely rely on a single thread being as fast as possible, obviously this means a chiplet, but we're already on this path.
Didn't realise they'd gone out of stock. Glad I got mine earlier this year.
Annoying that Corsair charge for it. Noctua tend to give free mounting kits for coolers which are not already compatible with the respective socket out of the box, just need to apply for it online. Probably baked into the Noctua premium price I guess.
OCUK sell their own retention bracket for AM4 CPUs, not as high quality as the corsair ones but still does the job in my experience.
https://www.overclockers.co.uk/asetek-premium-retention-kit-amd-am4-hs-04d-as.html
Will work the same for all AIOs using Asetek pumps, which includes all of the corsair AIOs.
Needs to be RED!!
The RAM latency and write performance is messed up in their test (possibly a BIOS issue), performance should improve further if these issues are fixed.Still doesn't do well in FC5 but FC5 always has been an outlier, i'm not worried about that and the 3600 has beaten the 2700X by some 22%.
For the rest, this is the entry level, none X 6 core very close to the much higher clocked 8 core 9900K. the Cinebech R20 single thread says it all, 478 vs 497, that's 4% to the 9900K but its clocked at 5Ghz ST vs the 4.2Ghz of the 3600, that is an IPC advantage of 15% to Zen 2.
Impressive stuff.
