Did the cheap Taichi boards ever get delivered?
Some got theirs, I cancelled my CPU order and of course they cancelled my motherboard instead. Still trying so resolve it, bought the Aorus Master instead.
I wonder how many lost sales Noctua have had through the years, down to their stubbornness in having this poo coloured fan?
I have had windowed cases for years and immediately discount the Noctuas due the colour.
Don't want to be looking at that.
Exactly! When somebody basis a whole disertation on just 1 benchmark then you know something is not quite right.The 3700X is rubbish because of CPU-Z? If only one person calls you something you can probably dismiss it, but when several people do it then it’s probably time to have a think about what you are saying.
I got mine no problem.
I dont know what to tell you there.If I don't use PBO my all core boost is 3.9GHz instead of 4.1 to 4.3 with it
Virtualisation with Ryzen Master does not work. Not Virtualisation in generalWhat problems are you guys having? Virtualisation is working for me. Vmware seems to have issues with Windows 10 1903, that i know about.
In games it's the same. https://www.guru3d.com/articles_pages/amd_ryzen_7_3700x_ryzen_9_3900x_review,24.html
Nope, together with them.
1. AMD could have postponed the price gouging in this generation, and do it the next one.
2. Virtually everyone complains when there is memory prices fixing, when there is CPU and videocards prices fixing, the same people take it as normal. https://www.techpowerup.com/257092/...eements-could-compromise-global-memory-supply
Had the Mobos been £150-200
@8 Pack This 4133 kit of Yours is fantastic. No go with 3733cl14 imc on My 3900x cant make it no matter what ill try.... wont boot to windows spend 2 hours trying to move from 3666 to 3733.
This is with 1.4 on ddr 1.15 soc and 1.05 on Fabric. Still will try to Tighten 3rd irpontance timings
You can get the very solid Asus TUF Gaming X570 board (with Wi-fi version) for <£200, which is enough for the 3950X. What do you want out your board that it wouldn't match?
YepDid the cheap Taichi boards ever get delivered?
My system is very noisy now, stock cooler sounds like it's going at 100% all the time, very annoying.
Think im going to spec myself a water-cooling solution.
I've just realised it's the fan on the motherboard that's making all the noise :/The slippery slope.
IndeedThe slippery slope.
Not looked into it properly to be fair. Everyone is mentioning £300+ prices. So I did not even know there was X570 boards under £200. What makes some of those worth double the price I wonder?You can get the very solid Asus TUF Gaming X570 board (with Wi-fi version) for <£200, which is enough for the 3950X. What do you want out your board that it wouldn't match?
