didn't say it should have the same performance but do yo really think 50% better = replacement.
It's a Vega replacement, with the 5700 being a Vega 56, and the 5700 XT a Vega 64. Even the pricing is similar.
I keep thinking of the good old days when it wasn't far off.
It's a Vega replacement, with the 5700 being a Vega 56, and the 5700 XT a Vega 64. Even the pricing is similar.![]()
Navi is inferior compared to Vega. Navi 10 has less transistors, worse memory technology, much smaller die size and ultimately replaces Polaris which is the 3-year-old mid-range.
Then we haven't even seen the best from AMD yet, as my 5700 XT is leaps and bounds ahead of the Vega 56 I used to own! If this is now mid-range.... good times ahead chaps, very good times!
We don't even hear what comes after Navi 10.
Given AMD's focus towards Zen, they have a team or two to work on the GPUs, hence Polaris -> Vega -> Navi, when they need more teams to work to at least three GPUs simultaneously.
Let's hope Dr. Su hires engineers to work on new GPUs!
If AMD "copied" Nvidia pricing, then the 5700 and 5700XT would be at £450/£500 to match the 2070.Why is it not priced like the rx590? Because greed that’s why - AMd is just copying Nvidia pricing
I was precisely because they launched them at £330/£375, that the consumers can finally get more bang for their bucks, may they be buying the Navi or the Super cards. Could the price have been better? Possibly, but it was definitely not "copied" Nvidia pricing.
The pricing isn't similar.
Vega 64 was $599 without the initial rebate.
Vega has always been the real high-end. It failed and quickly dropped to lower tiers because the architecture is borked and not suitable for gaming.
Navi, on the other hand, is never a high-end, and will probably never see a high-end product, if the next big thing is Arcturus or whatever the Next-gen is called.
^Arcturus I think will be the chiplet that they will use for their raytracing implementation, not a gpu, should be interesting.
How is the Vega not suitable for gaming? Not arguing, just genuinely interested, as mine steams along perfectly fine.Vega has always been the real high-end. It failed and quickly dropped to lower tiers because the architecture is borked and not suitable for gaming.
I’m pretty sure it’s already shown that Arcturus is just the code name for the Xbox one 2. AMD is using Navi for the next while at least and yes they can add more CUs etc to the die, AMD themselves also said the architecture is not complete - the 5700xt only has half of the architecture changes they want to do the other half comes next year
Just because it performs weaker than a rival, doesn’t mean it’s unsuitable for gaming.Although you have no problem to run the games at all, you notice around 30% less performance than the similarly sized GTX 1080 Ti.
Actually, GP102 is smaller than Vega 10, 471 sq.mm vs 495 sq.mm.
