The timings are all related to each other, so there are hard limits for what you can set. Primary timings are by far the most important, secondary timings is in the "diminishing returns" category for the vast majority of even enthusiasts. Unfortunately, some motherboards do not set sensible secondary timings by default when you tighten primary timings, hence the Ryzen DRAM Calculator is quite useful for knowing what to manually set them to.What's the logic behind tightening timings? Is there some mathematical formula that says when x = y values a, b, & c can be between a certain number?
What stops someone just putting in nonsense for those timings?
16 107 332 1 5 at 3600MHz![]()
I think there are a couple of things that are related.
Usually the formula tRC = tRAS + tRP should be followed though the calc doesnt alsways follow that rule. Even values for tWRWR SCL and RDRD SCL too are usually more stable. I guess there are related algorythms in the DRAM calc that the author understands. Still not got my 3600Mhz ram stable at 3600Mhz yet. I found the diagrams on the techpowerup website useful for the process for tuning the RAM, put together by the DRAM calc guy. DO NOT DISTURB THE SEQUENCE!
https://www.techpowerup.com/review/amd-ryzen-memory-tweaking-overclocking-guide/5.html
We seem to have the same RAM kit, I managed to run 3800 C14 so you should be able to run 3600Mhz C14 easy.I've tried and I've tried again with the dram calc but never had any luck.
I do have an idea tho what to do next. That is put the primary timings form the dram calc (or even the CL14 timings for this ram) set the volts to something like 1.45v.
Starting low like 2400MHz, slowly increase the frequency with each reboot/post until the PC refuses to post.
I mean even with my current ram speed I have to do the same. This is what I haven't been doing with the dram calculator. I just put all the timings in and try and boot and of course it refuses.
But until now I've forgotten that you have to go up the speed slowly.
I'll try again but I'm really not optimistic for CL14 at 3600MHz.
It's much better to run 3800 C16 / 1900 IF than to be 3600 C14 / 1800 IF because the IF increase far outweighs the timings.
My IF doesn't go higher than 1800MHz. Anything over 1800MHz and I get audio corruption in windows and the PC reboots.
Ouch, must be very bad luck since 1800MHz isn't even over clocked. AMD even recommends 1866MHz.
Once I get home I'll let you know, Im at work atm.If not too much trouble do you mind posting your timings and voltages for 3800C14?
Seems my bad luck continues then. I had a crap 1700 and my ram wouldn't do DOCP with my 2700x. I almost pulled the trigger on a 3800x twice in order to increase my chances of getting a good chip but after a lot of contemplating I decided just to save the £70 and get the 3700x.
Low and behold my 3700x has a very average IF.
Still I'm very happy with it.
I couldnt go over 1800 till i went to a X570 board from a x370.
So AMD this round improved the situation with ram. I reckon next round they will make PBO actually do something.![]()
