Next to nothing blob in the centre, and also used my 7 year old mx-2 lol.What did you use?
Will do the spreading method when going to mount it properly. For now, it'll do.
Your temps should level out hopefully - from advised application.Next to nothing blob in the centre, and also used my 7 year old mx-2 lol.
not gonna waste my new mx4 on an application that will be removed in the next week or so lol...LOL - and 7 year old MX 2? - You had an 8g tube of MX 4 in one pic (tight b*st*rd)
HDPLEX did a case, 26mm shorter but guessing this is due to the Silverstone fascia
https://www.hdplex.com/hdplex-h5-fanless-computer-case.html
aorus might be a bit thick though...
H5 378.5mm x 353.5 vs RVZ 382mm x 364mm
how to mount the PSU though? the psu is mounted to the psu cover and then the cover is screwed into the case cover...rotate 90 degrees with exhaust facing the ram - JUST ! chassis needs to be cut to allow cables to bulge out
@orbitalwalsh those AIOs won't fit, needs a slimline rad with a slimline fan
240mm rad won't fit unless with single slot gpu
This will be my favourite build logticky tap- glue- new hole and mount somehow - i'll figure it out... somehow..
oh dearnew hole
*The duck tape build.
oh dear![]()
oh dear![]()
I found this the more disconcerting - he really loves his cases.and mount somehow
Is there not another case that will fit the brief without essentially constructing a new one in the process?have a feeling might need a friend to 3d print new fascia - the two think strips the house USB and power buttons eat away at the max Depth of the case![]()
hah totally!(trouble is, it has great entertainment potential even if you don't)
i think the joke went so far above orbi's head it wasn't even funnyI found this the more disconcerting - he really loves his cases.
Or, he's compromised in his newly constructed 'aperture'i think the joke went so far above orbi's head it wasn't even funny
(or he's playing it cool)
