- 22 Jul 2014
- Oxon
Terribad. Proper chavvy. Do not want.
It looks so much better.
Black alloys (the diamond cut were finished), gloss metallic orange callipers, dechrome. Absolutely thrilled. It looks so much better. Tempted to get the windows tinted too, but worried that might be going a bit far.
Why is the M on the AMG badge wonky?
I think it’s the angle the shot is taken from.
Let you off then
I actually like it, think it’s just enough black and looks good. I’d argue the windows would be a step too far though!
That whole AMG badge is wonky, I don't think it's the camera angle.
Do they say 'V8 AMG' on the side as standard?
how much would that set you back for that kind of polishing?
Looks like they've done a good job, only a closer inspection would tell, but I am sure you gave it a good inspection and if you're happy that's the main thing, you got a good price too. I have my A4 coated with Artdeshine ceramic after one years ownership and two years later it's still easy to bring up to a showroom finish. I just top it up with a hydrophobic coat, such as Buster's done&dusted once a month...Really depends on the quality of the paint and how much work is needed as well as other bits to do like wheel nuts, trim, paint correction. I had a number of varied quotes but 2 stage polish and ceramic coat set me back 750. 2 full days of work. Had some quoting >1000.
