I was going to say! Still sounds very decent though.
My setup now is:
My idle temps are around 35C (which considering my room is pretty warm I'm happy with) and 70 under heavy load (cinebench)
- Ryzen 3600 Manual OC @ 4.2Ghz, 1.325V
- Deepcool Captain 240Ex
- 32Gb (4x8)Corsair Vengeance 3200Mhz 16C
- MSI Radeon RX 580 Armor OC
- NZXT H500
Agreed. I gave up with Prime 95 and instead chose to stress my system for stability in perceivable real world scenarios.
Nice temps! I have the same case. What's your fan set up? Are using the stock NZXT fans?
How do your temps compare to your stock clocks? My lows are in the 36C range but it rarely stays there under normal use (browsing) with all that boosting up and down going on. Did you find locking the voltage and OCing actually helped with temps?
PS. Are the temps from HWMonitor or Ryzen Master?
I did a lot of testing when I got the CPU, and that was one of the things I noticed at first so ended up returning the keyboard all together. Got a Ducky now because it does not require any active software.
