Support sent a suggestioin which seemed very sensible - a clean boot.
So booted the system with only Microsoft and Oculus services running... still didn't work!
How is this possible!?
Incompatible with my GFX card somehow?
Separate drives. C is an M2 SSD, D and E are both SATA.
Power supply is brand new, a Seasonic 650W 80 Plus Gold.
Bios is totally up to date, as I did that recently to resolve an issue I was having with shut downs.
I haven't tried the GPU in a different PCIe slot yet. I'll be getting hold of that GTX1050Ti on Tuesday, so I'll install that into a different slot and try two changes in one.
I've gone through most of the motions suggested in the thread except for a clean windows install.
My pc is an I5 6600k, 16 GB ram, Palit GTX 1070 super Jetstream, Gigabyte Z170XP mobo.....have noted OP has a Palit card......could this be a common denominator?
Well Bazza did a clean windows install and it didn't work for him.
I can't imagine that Palit GPUs are all somehow incompatible with the Rift S. That would be very bizarre!!
Can I ask you, do you login to windows with a local account or a Microsoft account?
Hi Melmac, my login is via a Microsoft Account - would it be worth trying a local account?
Sorry, I tried to methodically check all the suggestions and reply, but I missed that one - yes, I am using two separate power cables for my GPU.
I know what you are saying is correct about 2 changes at once. But I'm having a frustration break, so I am going to make the GPU change and the PCIe slot change at the same time anyway. If it fixes it, I'll be so pleased that having to then make a further couple of changes to check what was the defining factor will not bother me at all.
I also realise now I haven't tried your local account suggestion yet. If the GPU changes don't resolve matters, that will be my next attempt (a few days later again!)
 It's frustrating. I have lost track of things myself at this stage lol. Just noticed that you have a Z170 motherboard. Have you tried disabling XMP and putting in the memory timings manually? (if you tried most of the things in this thread, then you have probably tried this already) Also, make sure you remove any overclocks and software like afterburner etc.
Seems to be working ok now...... haven't changed anything else, and had already disabled XMP a while back. Not sure why issue has just disappeared, might have got lucky? - will keep an eye on the situation and report back if it starts to play up again.
