- 18 May 2010
- London
Anyone getting an AMD update through the Win Updates ?
Advanced Micro Devices, Inc - System - 2.2.0.121
I don't know what it is for, but it has to be downloaded (as ive got the Yellow Triangle back, with the exclamation mark, so i can't do any more updates, until i install it), Status :- Pending Download, Download Ready, and the Download button to hit.
EDIT:
Gets mentioned in a post on here, GPIO Driver.
https://www.reddit.com/r/Amd/comments/dglnck/tested_does_win10_november_update_1909/
, only goes up to 4.4 now
Managed to get an older version of that software which launched. Here are the screenshots and it shows as Samsung B-die which is meant to be one of the best?OK could you post here your DRAM Calculator screenshot and a screenshot from this application?
http://www.softnology.biz/files.html
So I can help you work out ram setting![]()
For some reason though it does not want to run at XMP speeds and wants more voltage.
Damn, I just noticed you went and got yourself suspended. Lol
I've never seen that second image before.
Do people use it for tightening timings?
The way I done it (very slowly) was adjust it down one point, test then if stable keep adjusting one mark down, test until instability then move onto the next timing.
Took me days!!
I don't have a link to hand unfortunately but there are formulas you can use to find the valid range for secondary timings and they need to be adhered to really as often you can go a little below the formula minimum without initially encountering instability but at some point it will bite you in the rear.
Don't you just use DRAM-Calculator-for-Ryzen to do that?I don't have a link to hand unfortunately but there are formulas you can use to find the valid range for secondary timings and they need to be adhered to really as often you can go a little below the formula minimum without initially encountering instability but at some point it will bite you in the rear.
I won't be spending days as I know it will make little to no difference for me for the gaming I do the fps has not changed at all going from 4770K @ 4.7GHz to Ryzen 3600 due to me playing 4K and capping fps at 60. Just going to tweak until I get bored of tweaking. Right now as I get the time I am enjoying learning about Zen 2 and how to tweak it.I've never seen that second image before.
Took me days!!
Took me days!!
The lengths to which people will go to get the last few% of performance.
I'd rather watch paint stay wet.
As the BIOS's and AGESA's (which are still immature) develop, could this not make your current parameters unstable? Meaning, on updating say the next BIOS with the 1004 AGESA (And new functionalities) you'll have to go through all that process again?
I'll just wait until BIOS's are mature and muck about then. As long as I can get 90% of the performance in 1 hour instead of 100% in days - I'll be happy.
Ram overclocking is time consuming it is true, but after u done it once it is easily repeatable and gains are actually significant. I just have picture on my phone from Ryzen DRAM Calculator with 3466 fast settings (where most of my timings coming from with some adjustments) after last bios update looked at the picture maybe like 2 times - remember nearly all of them alreadyThe lengths to which people will go to get the last few% of performance.
.Horses for courses, as mentioned some people enjoy it. If you enjoy it then where is the problem? I enjoy it myself and like to do it until it stops being fun. Every time I get hardware I enjoy doing some benchmarks and a bit of OCing.I used the DRAM calc 2 iterations ago. I too have overclocked my RAM. But I aint spending days doing it. Same as OC'ing anything. Some people will spend that amount of time if they are benchers to get the highest score, but if you are a gamer then sheesh......stable at higher than stock - that'll do.
