Yep, done that already. The stick that works always works. Which means it is not a mobo hardware issue.
If you can post some pics of your bios settings showing ram speed, timings, fabric speed and voltages it may help rule out a dodgy bios setting.
They are all on Auto and RAM speed and timings I have been looking on cpu-z (it shows the main one's at least).If you can post some pics of your bios settings showing ram speed, timings, fabric speed and voltages it may help rule out a dodgy bios setting.
Thanks Raven, that is quite a bit better than mine. Your one seems to excel at memory write and memory threaded and has slightly better latency.
Bloody hell mate, that is very good.
That's some seriously good RAM.
8 Pack? He probably put liquid nitrogen on themAsk yourself who got 4750?
What RAM and settings? That is similar to my RAM.
Thanks man. Seems mine is similar to yours and thont. Not done cpu, will do it later and post itJust because everyone else is....
Memory
CPU
