Dan A4-SFX V4 Mini-ITX Case
hopefully this works, used imgur
https://imgur.com/u838TLX
https://imgur.com/QFKKaqv
https://imgur.com/8tkSogp
https://imgur.com/KeY25iJ
https://imgur.com/PhrFN3P
sorry for the quality, didnt have the best camera or light to work with
but super happy with the outcome, to cram in the amount of hardware that i have is really something else,
full specs
amd ryzen 9 3900x (stock speed 3.8ghz pbo enabled)
32gb ddr4 3600mhz speed corsair lpx (2*16gb 18,22,22,42, 1T)
asus strix x570-1 gaming itx mainboard
corsiar sf 750w sfx platinum rated modular psu
samsung 970 evo 250gb m.2 ssd (boot drive for windows)
samsung 860 evo 1tb ssd for games and storgae
zotac 2 slot blower rtx 2080 ti gpu
dan a4 v4.1 itx case
astek 645lt 92mm aio water cooler for cpu
added a aditional noctua 92mm fan for cooling on the cpu and motherboard areas
the extra fan is a 92mm noctua and yes it does a fantastic job cooling down the mobo, chipset and m.2 especally, i noticed a 20+ degrees drop with it installed, sure the looks factor isnt there but i dont mind that, i care about cooling and a fan in this location does a really great job.
before the fan was installed my temps were
mobo around 60 degrees
chipset peaked at 81 degrees
m.2 would normaly hit around 58 degrees
after the fan was installed and tuned in a bit
mobo around 40 degrees
chipset down to 51 degrees
m.2 peaks at 38 degrees
so yeah definatly worth it for cooling XD
edit
have got access to a photo studio at work so will have some really good quality pictures in the next day or two
Looks very nice, still on the fence what to get, cancelled my Mjolnir backing.
i'd still go for the dan a4 maybe not a 3900x cpu as it does run warm, but hey i wanted to see what could be done and am pleased with the end result :)
its a 1440p pocket rocketship.
concider the mjohir if you want beefer cooling, dont quote me but doesnt the mjohir support 120/240mm aio's?
well guys and girls here are the hi res pictures of my dan a4 build
https://imgur.com/k7cCl2M
https://imgur.com/kGniMyG
https://imgur.com/VaIA12L
https://imgur.com/X4Dbg9F
enjoy XD
Looks fab, love the cable management. Really nice build, hope you feel chuffed.
Sat there when the Kickstarter launched, unsure, then watched Optimum Tech review and thought 'NOPE' especially when I saw what the case design did to the riser cable, and Ali's comments on the cooling performance
Yeah i was underwhelmed with that also, i'm favouring the a4 again now but have been looking at Sliger cases also.
The one i was looking at with both sets of panels would cost over £300 but this is smaller, cheaper, seems to be well made and i think i could cool my 9700k fine it and stick my reference blower back on my 1080ti.
The Sliger looks interesting, though larger than the Dan, 11 litres I think? I hadn't seen it before.
I think the Mjolnir was going to be closer to £400 with shipping, which is just madness for any small, or large case.
Yup I had a quick look at that one, way too expense esp for a Kickstarter.
It did get the backing though, they wanted $60k and when I last looked I think they had $130k. I could not justify that on a case though, especially when the reviews raised issues.
I'm still tempted by Mjolnir.
It would look great with a glass panel on the motherboard side, vented panel on the GPU side, and a 120mm AIO cooling the CPU. And there aren't many SFF cases where that set-up is an option. There's the Raijintek Ophion, but the vented panels are apparently awful. And there's the Sliger SM560, but it isn't exactly cheap in Europe once you add a window, the AIO kit, and shipping to the UK (€292, or £245). The LZ7-XTD is another consideration, albeit quite different to the other cases mentioned.
I'm wavering on price. £300 is a lot for a case, but if they hit every stretch goal (currently ~£12k short of the last one) then I think the base bundle represents decent value. Most of the competing cases cost ~£250 after shipping and taxes anyway.
I’ve been looking into this a lot today. Considering the reviews, I cannot justify the price. Needs to be at least 50% less to be something I’d consider. If I was going for this kind of case right now, I’d be looking at the Loque Ghost.
I have a Ghost, Best case I have ever had - can't recommend it highly enough. (I also have a Dan). Turn the internals upside down so the fan is at the top and you don't even need to use a top hat to get reasonable cooling.
