But of course. All types of workflow (programming, lots of work spreadsheet stuff and all the windows based daily life) excel in it.
What i always try to be mindful of is to shut it down if i will be absent for more than 5 minutes.
Thanks for the quick reply. Regarding the bolded, I don't really understand. You shut it down if you'll be absent for >5 mins, because that static element will be on the screen. But say you're on chrome browsing reddit for 4 hours everything apart from the scrolling text is a static element. Or if you're working on excel 4 hours, everything apart from the cells you're working on is static. Or having WhatsApp/Discord windows open, everything apart from new messages is static. So surely that'll just burn in?
For example: https://imgur.com/PTH9abh
Look how many static elements there are here. Fair enough you can hide the taskbar, and (vomit) not have a wallpaper but the rest you can't do anything about.
