ak, just taken an order of a 3600X and a B450 Arous pro (gigabyte) along with some corsair vengeance 3200Mhz ram and the damn thing constantly reboots![]()
On first boot the BIOS will go through Memory Training Cycles, so it will reset post sevral times before it boots into windows, maybe 5 or 6 times. when you turn it on let it post cycle for a few minutes.
(apart from the previous boot being unexpected)oh it's nothing like that. It may well have done this - but I'm talking about the windows installer barely able to finish after a clean reboot. Once I get to windows I get between a second and about 10 minutes before a reboot with no event logs(apart from the previous boot being unexpected)
It's alright,figured it out.That's an odd one. can you film it on your phone?
The PSU , although a superflower is a little under powered at 650w
I've substituted my 750w in and all is stable it seems
i mean its a 65 Watt CPU....Spoke too soon another black screen reboot. It just seems to be random, but in minutes now
5700xt nitro.Oh... that's great but my PSU is a 650 Watt EVGA unit, what GPU and what else are you running in that system?i mean its a 65 Watt CPU....
5700xt nitro.
I'm wondering if it might be great related. Stock fan keeps ramping like a Hoover
I've kept my eye on that. The 5700Xt is yet to get under load, as the black screen reboots happen randomly in Windows.
Would the nvme be at fault? I would have imagined windows to log errors if the file structure was borfed?
Have you applied XMP / DOCP to the memory? Or is everything at stock? You've installed all the chipset drivers as well?
I originally had xmp but took it off after the first few crashes. Yep, once I could keep Windows bored for more than a minute I got the latest drivers from gigabyte
I looked again at my results and I did find it strange my single core is fine. You know I think this is simply temps. All core 65c cinebench might be ok but someone else on reddit says limits start to kick in around 65-70c which is what I'm getting. I think if I used a good aftermarket cooler I would see different results so I'm happy right now. Just to clarify. Is cinebench all core supposed to draw like 1.378v? My single core draws over 1.46v! https://i.imgur.com/2mHDqLN.png
Also about the SOC 1.3v thing. I noticed if I set "Load Optimized Defaults" and went into Ryzen Master I'd obviously have 2133Mhz RAM but the SOC was 1.025v. The second I enable DOCP and booted back in to Windows, the SOC went to 1.3v
I have a feeling the board doesn't expect 3600Mhz RAM, and this is confusing it to go higher. It might be ok on 3200Mhz or so.
Edit: Might be a bug in Master? https://i.imgur.com/8xsNtPI.png
Try updating to the latest bios if you haven't already.ak, just taken an order of a 3600X and a B450 Arous pro (gigabyte) along with some corsair vengeance 3200Mhz ram and the damn thing constantly reboots![]()
