- 18 Oct 2002
- T'internet
I think your problem is probably USB related. You should try using a USB from the back panel...preferably one in a group that has no other devices plugged in.
After trying the Rift S it was nearly my ideal headset, I really hope Oculus come out with a revised Rift S, Rift X ? That has FoV of 130' at the very least, A refresh rate of 90Hz+, Resolution bump, And lastly an aesthetic that is a bit more attractive, That would be my ideal HMD.
I feel the Rift S has too many compromises compared to the rift CV1 - lack of decent audio, fixed IPD, poor contrast, and low refresh rate.
Don't get me wrong, it's a good headset, but the lack of a proper, full upgrade from the CV1 is disappointing.
If Oculus could have made a CV2 with inside out tracking, wider FOV and higher resolution without compromising on the audio and refresh rate then that would have been ideal.
Just ordered a rift s, can I go on and buy some games and install them in my steam library or do I need to wait and have steam vr installed
Check out the cd key stores online for vr games steam store and oculus store arnt always the cheapest.Nice one, thanks
will do thanksCheck out the cd key stores online for vr games steam store and oculus store arnt always the cheapest.
You must be talking about pre order, because i don't see any.These seem to be available in the UK again now, so ordered one.
