There was a news report the other day on lots of Argos stores still being open, as they're often inside Sainsbury's stores.My brother in law ordered one to collect from argos on a Wednesday but the Monday before boris shut all the shops, he's gutted
Mine arrived today. So they do turn up quite quickly if you can manage to order one.
Just got email from Oculus...thats mine dispatched...with yodel......
signed up and ready to go with software...
space on hard drive cleared for games...going to start downloading them now....
space in living room cleared so i dont destroy new tv or monitor...
im worse than a wean.....
G
Luckily I couldn't order one. Found out the specs are too high.
Thought an i5 7600k and a rtx 2070 would have been ok but the i5 would be a serious bottle neck for the 2070.
Was looking forward to vr but now knocked the idea on the head
I wanted it mainly for racing sims.. Do you think it would be OK still for that?You'd be perfectly fine on that. Bottleneck, sure, but a good experience still.
Also looked at the amd rx5700, would any recommend this instead of a rtx 2070
When exactly did you order?
What GPU do you have now?
A friend of mine runs VR on a similar CPU to yours with a 1060 pretty nicely.
rift s m8...
and just spent an hour looking at all the other crap i now 'need' to get...
controller grips...cleanable silicon mask......gunstock (essential purchase)
ffs....im panic buying vr
G
*soz m8...read that as 'what' instead of 'when'...
1st april at 0930...
Currently have a GTX 1060 6gb
I was looking on the net and basically it was saying that the 1060 can only do very low settings in games??.
Do you know how your friends run?
Yes you would certainly need to knock the settings down, I've tried his rig and it was far from unplayable though.
The Oculus Asyncronous Timewarp and Spacewarp do a really good job of interpolating frames though on lower end hardware.
