Caporegime
- 18 Oct 2002
At that price I'd buy two for sli
Not allowed on anything below a 3080Ti
Why settle for 2nd best?Not allowed on anything below a 3080Ti![]()
More 80 CU Navi speculation. I hope its true. Not exactly a reliable source.
yeah 505mm^2 isn't that what they are claiming or did I misread the fake news articleIf it was true an 80 CU Navi 21 would be 500m ^2
For me it doesn't need to be an "Nvidia Killer" it just needs to have the latest tech and be priced correctly, let the buyers decide what's best for there needs. PC master race get stung up in this my card is faster than yours BS when I can put money on it half the time generation vs generation side by side in game I bet most people wouldn't even see the difference lol
Why would AMd do this? Unless perhaps the ray tracing performance isn't good enough at the low end and mid range? But then does that mean the Xbox series x also has poor ray tracing performance???
Maybe they just don,t have enough graphical grunt to effectively use RTwhat wccftech fail to mention is that the the guy who leaked the rumour said something else too... he said that only the high end new gpus (5800/5900 series) get rayvtracing, the rest of the new gpus (5600/5700 series) do not support ray tracing.
I would not be surprised. At face value it sounds random, Nvidia allows RT all the way down the stack. But Nvidia has special fixed function hardware.
AMD is re-using shader cores that would otherwise be doing raster workloads - so if you don't have a lot of shader cores, it could be very difficult to main acceptable RT and acceptable Rasterization performance in the same 16ms frametime, which is how you do Ray Tracing.
I find it funny this "nvidia killer" name is sticking like there's any truth behind it. Clickbait at best for tech sites.
People love it. Classic David vs Goliath. We all want a good story, even if they don't turn out that way.![]()
It definitely is. It's up 60% from Ryzen 1's release. 18% YoY.More investment in R&D is what's needed, which is hopefully happening now.
