Now that i actually have some experience with RDNA1 i'll add to it.
Power consumption on the 5700XT is all over the place between different vendors with the same reviewers. They range from 180 Watts to 220 Watts. Mine from personal experience is 200 Watt's out of the box, reviews that i have seen show the same thing, 200 Watts.
I have fiddled with mine, increased the actual running clock speeds from 1.9Ghz to 2Ghz and brought the power consumption down from 200 to 160 Watts, if AMD binned these GPU's keeping the better Silicone for the 5700XT's they wouldn't need 1.2v, that's WAY over what mine needs, which is 100% stable at 1.035v.
The fact that RDNA2 is in consoles with 2300 Shaders at 2.2Ghz in the case of the PS5 and 3300 Shaders at 1.9Ghz in the new XBox indicates AMD have improved the power consumption significantly RDNA2 vs RDNA1, the shaders despite the deflated mediocre view people have about RDNA1 are actually very efficient, compared to my 1920 Shader GTX 1070 at the same clock speed my 5700XT is anything from 50 to 70% faster and the 1070 used more power.
I have built a high tessellation map in Cryengine 5 to put AMD's historic weakness to the test, it humiliates the 1070 in that test.
Navi (RDNA1) is much better than people think it is, yet again people just had too higher expectations expecting it to crush a 1080TI and it didn't, the 1080TI has near 4000 Shaders and a 384Bit IMC, the 5700XT is small GPU punching way above its wight class. its a good GPU.
Don't expect an 80 CU RDNA2 GPU to beat a massive Ampre, but it will be a good GPU in its own right.
