Ryzen 3900X thread
14 Apr 2009
Cheshire
I think gigabyte have nailed it this time round. either x570 or soon to be released b550. great looking boards, decent enough bios. UK RMA if needed.
I couldnt get a way from the word tomahawk and arsenal gaming...what am I? a child?
Who comes up with this nonsense. Also the taichi with the gears? omg...
gigabyte have the HW and the design this time round.
15 Feb 2014
Peterboghorror
Thanks for the comments on the Tuf, sounds pretty much what I'm looking for :) Good solid all rounder, don't really need any flashy extras.
I'm a little worried by the positioning of the chipset fan under the gpu though.
Don't. I have one and cannot hear the fan in normal operation, in heavy use it can't be heard above my Dark Rock Pro 4 (which is one of the quieter coolers available). Install the latest BIOS when you get it and you'll be golden. Mine runs 32gb of 3200 ram at 3733 with RAM calculator fast timings. Great board.
2 Feb 2010
East Midlands
Thanks for the comments :) Got a while to wait for the CPU to be delivered, so will keep an eye open for a good deal on the Tuf in the meantime.
16 Jun 2015
It will be fine I couldn’t hear it at all over a air cooled gpu and it has a decent intake with no grill like gauze in front of the fan (like the highest spec Asus boards seem to do)
2 Feb 2010
East Midlands
I went with the Gigabyte Aorus Pro x570 as I couldn't get past the colours or the name of the ASUS TUF board.
Very similar in specs and price too :)
Yeh, I'm not overly enamored with the colour and name of the Tuf. But I always prioritize features, reliability, build quality and price over all else. That said, if it was pink with polkadots and named fluffy unicorn pro, I wouldn't touch it with a barge pole no matter what :p
8 Nov 2002
Kent
https://imgur.com/a/2uxhgym
In 33, the last picture I have my 20 pass TM5 and DRAM calculator memory benchmark. This is with new timings from version 1.7.2 of DRAM calculator for my 3600M2ZC18 Corsair Vengence Pro. I'm just doing a test with reduced memory voltage right now but I had to restart the test, there were no errors but it seemed to be stuck on test 13 with 1.0 Sec/Gb and cpu was not maxed and RAM usage was low.
As soon as this test completes I'll swap in my Patriot Viper Steel 4400 kits.
@megatron
When you have the Vipers fitted.
In Dram calc be sure to enter them as profile version 1 and memory rank 2.
Only use the FAST option I mean why would you choose anything slower :)
Will remember this.:) (Its called A2 for high quality now though, Buildzoid talks about different PCB layouts here: https://www.youtube.com/watch?v=Yw70_UI_bkY)
I'll be mindful of this too:
https://www.overclock.net/forum/13-...membench-0-8-dram-bench-745.html#post28447136
18 Oct 2009
I ran some tests today including default Memtest 5 V3
https://1drv.ms/u/s!ArMHGD-yylU7gdsjyK2jknef1JXTig?e=hruw9D
The Dram calc tests were with v1.72 but although my timings are all the same I am still running the termination and Cad bus block settings from version 1.70
I know your still looking for stability but they have made a big difference to your scores so far.
I see you are still using the memory rank 1 option.
Try with the rank 2 settings see if your scores improve.
22 Apr 2009
Birmingham
Whilst I'm happy with the performance of my 3900x, I'm still confused with xfr/pb/pbo and their impact on performance so will welcome your thoughts.
Using Cinebench R20 as a benchmark
Stock = 6900-7000 / boost to 3950/4000mhz / temp at 72c (multiple runs)
Pbo off = 7100 /4050mhz/68c
Undervolt and pbo off(0.102) = 7350 /4175mh/65c
Undervolt and pbo on =7200 /4100mhz /63c.
I've tried under voting at different increment from 0.01 to 0.1 at 10mhz increments, anything less than 0.102 has a negative impact on scores and temps.
I'm confused as why it boost lower with pbo on? I've configured pbo to use motherboard settings, and I've also tried manual setting to max out the three settings.
In games and general usage, I will get 2-3 cores hitting 4.6 to 4.625 with the other cores hitting 4.575 on the first chiplet.
As I said, I'm happy with the performance, but confused with the route taken to get the performance.
