- 18 May 2010
- London
Can raising SOC voltage help at all achieve higher FCLK?
VDDG is the fclk voltage.Can raising SOC voltage help at all achieve higher FCLK?
@opethdisciple
What timings are you using atm ?
Try the SOC at 1.2 if it works just lower until your happy with the result.
I used to use 1.2 SOC on earlier bioses until i realised the first port of call for instability was adjusting the Termination and Cad bus block settings.
Coming back to my earlier issue of high idle temps, boy does this PC get hot on a hot day. I noticed the CPU was in the 70-80C (usually in 60s for a gaming load) region after a short session on Tomb Raider and the case was noticeably hotter. The AIO liquid was around 15-20C hotter than idle (>50C), I have had similar issues in previous summers and unfortunately the desk already in this bedroom (rented) has a small and slightly restrictive enclosure for the tower. I currently have my Kraken X52 sat on the front intake and 1 x 120mm fan as a back exhaust and 1 x 120mm at the top - also as an exhaust. I assume not enough cool air is getting in and/or not enough warm air is been taken out, so will have a think about how to improve and likely buy a couple more fans.
Those prices are insane. My X570 Tachi was under £250 from "competitor" on launch day.
Perhaps they are recouping some B450 4000 series bios writing expenditure.
Lol keep forgetting about that.might want to remove the competitor before admins delete the whole post
B550 prices, ridiculous.
MSI
US price excl VAT / EU price incl VAT
B550 Gaming Carbon Wifi : 219$ / 249€
B550 Gaming Edge Wifi : 189$ / 209€
B550I Gaming Edge Wifi : 199$ /219€
B550 Tomahawk : 179$ / 199€
B550 Mortar Wifi : 169$ / 189€
B550 Mortar : 159$ / 179€
MSI B550-A Pro : 139$ / 159€
