- 1 Jun 2014
Hopefully I won't be too long after tomorrow at that rate. Please post all your feedback guys!
so you all keeping yours with the yellow tint ?
I have three u2719D and i had to send 2 back for replacment for bad light bleed as my first one is very good but has a littile but the other two, jesus how they made it out the factory i never know. I am tempted to go for three of these if the next two u2719d are no good but i am not to sure on this yellow tint as that would wind me up as well.
not only that the U2719d are supposed to be there high end models this is why i am asking about these as they seem to be in the same price mark.
How do you test got this yellow tint? I will check my unit this evening.
Mine arrived, looks fine no obvious issues that I can see. It's too light at the moment to really check for IPS bleed but nothing super obvious.
Mine looked fine out of the box. Might be worth resetting to factory then installing the drivers.So what did people do right off the bat? I'm a total noob when it comes to monitors, mine just arrived, and I've hooked it up via Display Port, the whites look very yellow though. I haven't fiddled with anything or installed anything, so I'm not really sure what I'm supposed to do next?
Edit: Actually it's not just the whites, it's like every colour haha, I guess I gotta install the drivers etc?
What drivers are people installing?
When I go to the Drivers, Manual and Support section it takes me to a page for the P2720DC with a driver dated November 2019.
Yep it is, however when I just restarted my PC it came up saying ''No DP signal can be found'', tried it with HDMI and the same thingIs this supposed to be the successor to the S2719DGF anyone know? Looking at getting a 2nd 1440p display... (currently on S2719DGF and 2 old BenQ 1080p monitors)
Dell seems to have dropped the S2719DGF from the website and stock is scarce on it. So sounds like discontinued, possibly for this model?
@Pookzz is your resolution set correctly @ 2560x1440?
Mind if I ask how it compares to your U2715H? I'm wanting a monitor that's good enough in terms of colour accuracy that I can use as a main monitor alongside my U2715H.
I wont get them setup side by side until the weekend so hard to tell, literally took the other one of its VESA mount and dropped this one on. In terms of design the screens are almost identical (from the front) so they'll look fine side by side. The stand on the new one is a lot more gamery, I might get a dual monitor VESA mount for them.
it looks like the monitor is still discounted but the code I had for 10% discount no longer works and student discount doesn't work either. Has anyone had any luck getting a discount?
