Just put together office pc for my missus:
Ryzen 5 3600
MSI b450 pro-m2 mATX max
Corsair 32 GB 3000 MHz
Crucial p2 500 GB nvme
Noticed it was boosting (before applying all drivers,updates) to 4275 MHz on all auto (xmp on).
This computer feels so quick for an office pc![]()
I would say that the vast majority of users run them at stock because Zen2 famously does not respond so well to overclocking vs Intel. The gains are not significant and good performance can be had simply by having a good air cooler that means the CPU can it full boost without any hassle.Who runs it at stock... Pointless, they are all taking nonsense compared to real world users
It full boosts as you call it to 4ghz for anything other than single threaded tasks. And only one core for those.I would say that the vast majority of users run them at stock because Zen2 famously does not respond so well to overclocking vs Intel. The gains are not significant and good performance can be had simply by having a good air cooler that means the CPU can it full boost without any hassle.
If you are saying that all review sites, that are producing consistent and measurable results, are all talking nonsense then perhaps you are the one talking a wee bit of guff in this current discussion.![]()
Which board please mate?Avoid asus bios 2103, it is very problematic and my system was unstable, random reboots and drivers crashes.
Nice. I have the same mobo and SSD (2TB though).I got a good deal on a 3700X so went all in and now PC is up and running nicely
I managed to OC the ram to 3800MHz from 3600MHz and set timings to 16-19-14-34 from 18-22-22-42.
Mine idles at 39 degrees with h100i. It used to be 34 but I have Corsair iCue installed for the keyboard which raises idle temps slightlyWhat temps do people get at idle for a stock 3700k? Using a b550 mortar and it idles at 55c with a
Alpenföhn K2 Mount Doom CPU Cooler.
Seems a bit high from a quick Google, I'm wondering whether I might have put the thermal grizzly kryonaut on badly... Did a thin layer with the spatula.
Thanks, so I'm probably on the high side, even taking into consideration the current heatwave.
There are too many factors to consider (room temp, case airflow, cooler, cpu itself, how you are measuring, etc.). I'm using a H100i too and my 3800X averages 50C at the moment. It was only mid thirties before the summer (+ I have increased voltages and haven't cleaned my front case filter for a while).
I wouldn't be concerned about 55C idle, as long the CPU is kept from throttling under load.
I run my 3600 at stock.
