Just set it to Game picture mode and check True Motion is switched offWithout trawling through the whole thread is there any settings I want off or on for gaming?
https://forums.overclockers.co.uk/posts/33752270/
And enable 10bit in Nvidia control panel for HDR.
Edit: forgot to tag you @Colonel_Klinck
I don't seem to be able to enable 10bit in the control panel. I have 2560x1440 120 Hz 32-bit but the only option for Output Colour Depth is 8bpc. Any ideas what I"m missing??
I have an Acer X27 but thinking of selling it and buying the LG. Will games look much better?
Does the display suffer from the possibility of screen image burn? If so, is it wise to game for long periods of time on the display?
I can see some of you chaps have been able to update your software version, but whenever I ask it to check for updates it always comes back with "No updates found".
My software version is 03.00.60.
What's up here, is there a menu option I'm missing somewhere?
Have you enabled automatic updates?
Another work around is to wait another month or two for John Lewis to get stock of it (due end of September to mid October) and take out the £140 insurance policy which is the only policy on the planet to support burn in issues so at least peace of mind for 5 years.
Mine doesn't have auto updates enabled but still came up and said there was one and gave me the option to install or not.
