.....The remaining 3.5GB can be and will be used for games. Therefore, it's not 10GB, it's 13.5GB if you want to be technical.
And, depending on engine could dip into system memory if need raising 13.5GB to 14-15GB. This is do to obvious updates to the xbox which will reduce memory footprint. As has been the case in prior update releases.
What a load of tripe! You literately just made that up. LOLSorry, but now you're just making up drivel to suit your argument.
Based on what is known about the Series X, 13.5GB of GDDR6 is available to games. Of that, all 13.5GB can be used for CPU tasks like file IO and audio. But only 10GB can be used for GPU tasks. While the 6GB of slower GDDR isn't all that slow in absolute terms, it's significantly slower than the "GPU optimal" portion.
It might suit your argument better if the GPU portion is larger than 10GB. But it isn't.
As you put it: Sorry, but now you're just making up drivel to suit your argument.It's literally the entire point of having a shared RAM pool.
"Memory performance is asymmetrical - it's not something we could have done with the PC," explains Andrew Goossen "10 gigabytes of physical memory [runs at] 560GB/s. We call this GPU optimal memory. Six gigabytes [runs at] 336GB/s. We call this standard memory. GPU optimal and standard offer identical performance for CPU audio and file IO. The only hardware component that sees a difference is the GPU."
6GB is intended for other functions, which don't need the high performance of the faster RAM. Hence Microsoft saved some pennies by splitting the RAM asymmetrically. If more standard RAM is needed, it can be taken from the pool of faster RAM.
The Series X has literally been designed on the principle that <10GB "VRAM" is sufficient. If Microsoft didn't believe it to be enough, then more of the Series X's RAM would be at 560GB/s.
We have the same argument every time nvidia skimps on memory. And our fear are always proven right down the road.
VRAM shouldn't even be a consideration for any graphics card north of £400 notes. But evidently shareholders matter more than customers.
Who are console developers making games for nvidia or amd hardware? Huh?
Next gen consoles have double vram and only the 3090 got double vram
rtx3070 and 3080 is going to age pretty fast
I'll just wait the the 20gb version in November or sommotJensen, Gibbo and I recommend you the ASUS 3090![]()
They have double the RAM, not VRAM. In practice it has about 10gb usable as VRAM.
Not a prob, I will be on the 4000 series before they ageNext gen consoles have double vram and only the 3090 got double vram
I'll just wait the the 20gb version in November or sommot![]()
When 8 GB is no longer enough, why wouldn't people think 10 GB is going to be a problem soon™ enough also? I'm buying it anyway, but let's not kid ourselves about the limitation. It's absolutely a compromise but who knows exactly how and when it's going to be a real problem.
3080 doesn't appear to have any issues trouncing the 2080 Ti in Doom Eternal.
