Yes, you buy VD on the quest app store, then side quest to install the patch then within the VD menu you launch games - yes Minecraft does work via VD
Google virtual desktop quest and there are loads of simple guides to set it up
Sorry, a bit of confusion here. I have VD already set up, running Steam VR games fine wirelessly over a TP-Link AX6000 router. Though, my latency when playing games fluctuates around 30-70. I was confused when melmac said he/she was getting 20ms, but that was just in Oculus games, but didn't realise that Oculus's own PC app worked like Steam. I can't get Minecraft to work from that by the way, it just comes up with an error saying "Oculus Rift not detected"
My set up is PC > connected to wifi downstairs. PC > connected to Wifi 6 router in bedroom, running only Wifi 6 with no other devices. Quest 2 connected to router via wifi.
I'm currently having an issue where my PC wifi will cut off every now and then, and I was wondering if it might be the two wifis conflicting with each other. Though my PC wifi is 2.4ghz, and the router is 5ghz with all other modes turned off.
Another issue is the latency isn't THAT good, and it's within 1 metre of my headset.
Update: Tell a lie, I just tried No Man's Sky, both 72 and 90hz (if that works after setting it), and it ran between 25-30ms pretty consistently. It's the loading screen where it suffers. Gotta remember to alt-tab to the Virtual Desktop streamer tool while in the game to see the latency for (VR) and not (Desktop), which it says when you're not running anything.
 Thanks.
