AMD Navi 23 ‘NVIDIA Killer’ GPU Rumored to Support Hardware Ray Tracing, Coming Next Year
Status
Not open for further replies.
Regarding Time Spy we don't really know what the AMD stack is and I don't really know what the bottlenecks are in Time Spy - it could be that AMD's approach is particularly good or bad at different requirements of the benchmark depending on how heavy different features are depend on shading and the various components of ray tracing and their impact on the pipeline.
10000+ from Patrick (supported by kopite) .. I am being conservative up to 11k maybe
https://mobile.twitter.com/VideoCardz/status/1319210484810289152
Ah ok, well that is the 6800XT from what he claims cause the 6800XT codename is Navi21XT and 6900XT codename is Navi21XTX. That FSU score is directly on par with the RTX3080 while the RTX3090 gains another 2k points on top of that
So here is a list from what I gather
RX5700XT: 6700 pts
RTX2080ti: 8600 pts
RTX3080: 10500 pts
RX6800XT: "Scores over 10k" - I'm assuming 10500 like the 3080
RX6900XT: Unknown - but given it's rumored to have 10% more CU's I'll assume its 11500 pts
RTX3090: 12500 pts
So the 6800XT is 57% faster than the 5700XT and 22% faster than the 2080ti
Ah ok, well that is the 6900XT from what he claims. That FSU score is directly on par with the RTX3080 while the RTX3090 gains another 2k points on top of that
I don't think that AMD will call an RTX 3080 competitor RX 6900 XT. They called RX 5700 XT in line with RTX 2070.
It could be the RX 6700 XT's score - competitive or slightly faster than RTX 3070.
link? I can't see it on the usual news sites
It's 6800xt btw (fatfinger typo). I've changed the original post
It's 6800xt btw.. I've changed the original post
I wouldn't hold too much to what particular model it is in that regard - even those who seem to have some idea as to Navi 21 aren't in agreement as to the models and I'm not sure anyone has it right yet.
As far as Time Spy goes it is a bit of an odd one as it uses a mixture of approaches and isn't "pure" ray tracing but also not like some of the hybrid approaches - if AMD has a card that roughly trades blows with the 3080 or a slither behind it as the only genuine numbers suggest then that card likely comes in somewhere between the 2080ti and 3090 for Time Spy depending on what the actual demands of the benchmark are in terms of packing data for RT structures, memory OPs and so on and how well AMD's approach handles that.
Do you think it could scale similarly to RX 5700 xt between fsu and timespy?
This is literatly what I posted as my estimates a few minutes ago
Maybe they guy is reading this forum and just copied me
RX5700XT: 6700 pts
RTX2080ti: 8600 pts
RTX3080: 10500 pts
RTX3090: 12500 pts
See lol
I don't know enough about how they approached the feature implementations in Time Spy - I'd hope some of the shader refinements gave an improvement in performance from FSU to Time Spy compared to RDNA 1 but I can't be sure.
If its meandering around the level of 3080, both beating one another in select cases, its a great achievement to get from a 5700XT to this. They need to have stock and it be around £600 then its job done.
I’m sorry chap but Twinz is entirely correct, names are irrelevant it’s just price, performance and power consumption that matter (maybe aesthetics if you like your bling too).
Your argument about the entry level being £700 in that case is missing the point. Just because older GPU lines went by a certain nomenclature doesn’t mean you should expect the same from a new line.
Simply look at what performance your budget gets you today compared to the last time you bought and make your buying decision. Then look at the name and whether it’s called the FerretMAXXX 30000 or the Navi 21 should make no difference at all.
You're not comparing like for like though: FerretMAXXX uses hairy capacitors and there are numerous reports of biting.
Small if false
I followed Ryzen but didnt upgrade till 3000 series. AMD built the cores and speed gradually refining it, they offered the zen and zen+ cheaper till they caught intel. This is the same approach I think they will do with Radeon, they cant charge the same till its the same performance and even then they only got bolder with Zen this time as it is purely better than intel and the mindshare is now established (took them a while to grow it).
That's my point, when they had something top end they priced it accordingly. A 3080 level card would be great as a bargain, but AMD know it's worth good money.
Ch-ch-ch-ch-choooooooooooooooooooooooooooo
I'm with you, ride this hype train all the way down to hell!
Status
