I'm gonna say this game is probably the only exceptionTry the Crisis remastered benchmarks with everything set to can it run crisis lol
it runs much worse then original oneI'm gonna say this game is probably the only exception![]()
Joys, just when you think you had conquered all this happensit runs much worse then original one![]()
do you like the look of it?Got my Inno3d X2 yesterday. Put it on water today.
This was a long time coming.
Yes. I'm really pleased. Lights up great because of the large amount of plexi. Photos of that don't do it justice.do you like the look of it?
Joys, just when you think you had conquered all this happens![]()
loooool, is it that bad?! jeeeezI know I put mine through it and got a buttery smooth 22.5fps lol
It's in alreadyCongratulations @Toothy1911 ! Finally got the beast on water, whens it going in or have you done it already? Need more pics![]()
LOL, bet its soul crushing for your card"I just can't do it Captain, I don't have the powwwwerrr" lol
Yeah it was awful!
Same, i really wanna see what it looks like tbh... its so tempting to sell this when the FE block drops and get a 3090 FE instead lol! Yes its a waste of money swapping for me hahagod i need the fe block to drop so bad, tbh on air my card stays around 65 degrees and clocks hover around 1920-1950mhz
Can't be that bad! Show us man, im tempted to migrate over to a XL but i like this small mid tower a lot.It's in already
My current setup is embarrassing. I'll be doing a new O11 build when their mini case comes out.
You can play with curve, it's fun while we wait;]god i need the fe block to drop so bad, tbh on air my card stays around 65 degrees and clocks hover around 1920-1950mhz
That's a decent score tbh, i dropped my temps down to 37c max on full tilt and did a run on cold start with ambient temps around 20c and managed just over 14k with a +180 and +800. I feel it can do more if i had a higher power limit, the +104% only allows upto a peak of 370w max.my oc fe +150 core and +500 memory in port royal scored
https://www.3dmark.com/pr/434877
have to set an aggressive fan curve as msi afterbuner beta 2 isnt working properly i have to start the curve at 75% which is read by the gpu as 47% fan speed, and beta 3 of msi afterbuner is very flakey with the oc i cant get anywhere near the clocks on the latest version
still very happy with my result though![]()
It could be a thermal limit, best way to test that is to have a fan at full tilt blowing on the back of the card and test again with a higher memory clock. If you still get instability then its probably the card but if you don't then its the latter.i'm not sure if its my card but i can only hit around +600 on the memory before i get instability, the core can go up to +170 but temps tip over 70 degrees at that point, maybe when the fe block drops i could push more memory speed?, my peak power draw for the card alone is 417w with a 114% power target too, its a hungry boy under load
Wish mine could hit 417w haha! I'm so limited at 370w, the card has more to give but i can't give it!
