No luck yet?i wish i had and fe because i want a 3080![]()
That’s great help mate I have a Zotac 3090 to so will look at doing the bios upgrade. Thanksone secsent to Jay85 a few days ago but for public view now.
PLEASE NOTE I TAKE NO RESPONSIBILITY IF YOU FLASH YOUR CARD WRONG, THE FOLLWING LINKS ARE TO BE USED AT YOUR OWN RISK, IF ANTHING GOES WRONG THERE ARE INSTRUCTIONS ON HOW TO FLASH BACK
first of you'll need the gigabyte vga bios which can be found here (max power target 110%)
https://www.techpowerup.com/vgabios/224963/gigabyte-rtx3090-24575-200904
next you'll also need nvflash 5.66.0 which can be had here
https://www.techpowerup.com/download/nvidia-nvflash/
lastly here is the link for the steps to flash your card
https://www.overclockersclub.com/guides/how_to_flash_rtx_bios/
follow all the steps as instructed in the walkthrough, if at any point up until the flash process you don't feel comfortable just exit and nothing will happen or flash over.
if any of the above links arn't allowed please let me know so i can remove them
nope.. I am a patient guy... realistically probably next yearNo luck yet?
Oh amazing and it looks like black and silver on offer?
We see that there is some debate about the port placement on the 3080 Founders Edition Vector water block, so let us address that topic. Rest assured that everything was well thought out. The water blocks will come with an included backplate - in a silver finish in case of the black water block and vice versa - and two sets of connection terminals so users can swap them out if needed. One terminal has two direct G1/4" ports on the side, while the other one is more conventional with four G1/4" ports going through the terminal.
that's a backplate? why its so thick ... I cant imagine it will look good
oh ... right... now I see itthat's the whole block mate
Finally GIGABYTE BLOCKS !!!!
https://pl.aliexpress.com/item/1005001604023063.html
thats why i poped it here mate that got EAGLE in poland ordered one also.Shut up and take my money!
