I am finally on V23 on both my computer and Quest 2.
Haven't had a chance to try anything out yet.
Is that on the beta channel or standard channel.
Hello guys , i dont have Link cable for my Quest 2 so i wonder if i can get superior picture Virtual Desktop via Link compared to Virtual Desktop and wifi6 router ? Has anyone compared HL Alyx PQ in both ways ?
Thanks !
Picture quality is better using link for sure, but for me Virtual desktop is far superior still, wireless is the gamechanger and playing half life Alyx with no tether just feels amazing.Hello guys , i dont have Link cable for my Quest 2 so i wonder if i can get superior picture quality via Link compared to Virtual Desktop and wifi6 router ? Has anyone compared HL Alyx PQ in both ways ?
Thanks !
Yeah the climb as well annoyingly, I still prefer VD over link in most games, but link has it's place now it's out of beta.Recent link improvements means you can make Link look better than Virtual Desktop, partly because you can increase the bit-rate far beyond what Virtual Desktop can do, and because Oculus have added other quality improvements and performance options. But it requires a really beefy PC to get tge best out of it and a decent link cable.
The latency on Virtual desktop is more than when using Link, but at the lower bit rates it seems to be sharper and have better quality. But you need a really, really, good connection to your 5ghz router - ideally in the same room, otherwise you get frame drops, latency and compression issues. It's a bit like that old rhyme - When it's good, it's very, very good, but when it's bad it's horrid.
Also not all games work on Virtual Desktop, especially some high profile Oculus games like Stormlands.
yeah 150mbps, but at that bandwidth latency might still be a tad too high, just have to experiment.thanks for the replays guys ! My router is in the same room- about 3 meters from the Quest so guess this wont be a problem . What is the maximum bit-rate that you can set on VD ? 150 Megabit/s ?
And is this depends of the HEVC encoding power of the GPU ?
Finally swapped out my elite strap for a DAS recently (I now have 3d printed sides instead of the cable ties but can't be bothered to take a new picture.)
It's so much more comfortable and the wheel doesn't feel like it's going to break everytime I use it, which is nice, elite strap got returned to amazon as i thought it was a bit ***** for the money.
Seeing a few complaints about tracking popping up from people with the new update. Might not be such a bad thing to be at the back of the queue.
After testing the update for the last hour, I can confirm that my tracking isn't as good as before. Missing notes in Beat Saber for no reason.
Also my Quest 2 has slowed down quite a bit. It takes longer to load games and then in some games there is stuttering. I didn't have any stutter or missed notes when forcing the 90Hz mode from sidequest.
Bit disappointed to be honest.
.The latency is shown on the streamer app in windowsOk , i see ! Is there some way to show the latency real time statistics on the Oculus display ? It is fine if it is under 40-50ms - right ?
On the flipside after the official update I am far more accurate in beat saber than I was wit the sidequest 90hz patch and games take no longer to load than normal. I do get stutter in the homescreen, but none in any games, and I got the patch the first day it launched.After testing the update for the last hour, I can confirm that my tracking isn't as good as before. Missing notes in Beat Saber for no reason.
too much lol.Looks great. How much did it all cost?
too much lol.
The DAS was £110 with shipping, but worth it imo, the VRcover for the DAS for extra padding inside was £20.
I managed to get some 3d printed sides for free as someone on reddit made them for me.
The audio sounds great and it is so comfortable.
