ok so messing with the CPU/FCLK and failed to post. ok normal.... just leave the board and it will retry then reset the CMOS if it fails to boot a few times right?
Well my B550 PRO doesnt seem to want to do it. it also wont clear the CMOS with the jumper (turned off the PSU waited for a bit, cleared power from board pressing power button, shorted jumper for 5-20 seconds etc)
The only thing that clears it is to take out the GPU, remove the battery and then short the battery terminals on the board then reinstall the battery and the GPU.... obviously this is incredibly infuriating and inefficient when you may need to clear the bios 10-20 times in a row when messing with memory/overclocking etc...
Anyone know how to make it auto-clear the cmos after X boot loops/boot failures etc?
Thanks
Thanks
