Aint gonna lie guys cyberpunk 2077 looks mint on this monitor (ultra RTX settings)
Yeah, absolutely mind blowing. Running at 4K with max settings.
Use the ultra rtx preset then remove lens flair, film grain & motion blurWhat settings are you guys using? I found the best visuals and gameplay on my Tuf 3080 are actually playing at 1440p with RTX Ultra settings and DLSS set to quality. The game by default out of the box set DLSS to Ultra Performance which renders at 720p and upscales, which was looking slightly less spectacular. Hardware Unboxed also have a good round up of various settings up:
Sorry if this is going off topic a bit![]()
Do I have to connect the monitor to PC via usb to get the RGB lights working?
I don’t think you’d see any difference tbh, but if you’re never going to reach more than 95Hz that’s a viable option if you wantDon't suppose anyone is using this for photo editing? If so, have you noticed a difference in 10 bit mode with dsc on? I'm tempted to leave it at 95Hz, as realistically eve in older games I doubt I'll see 144Hz.
Thanks - I'm in at least 1 gpu upgrade a way from 95 fps in modern games. Is it easy enough to enable on the fly?
I had the same issue - it was fixed once I turned off Smart Energy Saving under General from the OSD settings.
I had the same problem, this helped me
I feel like it should have been mentioned in reviews or pinned somewhere lol.
I didn't even unbox the stand, just straight onto a vesa arm. It's pretty solid once it's on there.
Is there a way to disable the white flashing RGB cycling every single time you wake up the monitor from sleep? I thought it only happened when you turned off the monitor. :S
I think you have to use the LG control centre software to do that.
It is annoying getting flashbanged by RGB everytime you turn on the pc haha
