Hi - can I ask all G9 owners, have all the main issues now been ironed out? I had one way back in July last year but returned it due to the seperation of the bezel issue and then after that there was the shortgages, recalls (or not recalled) etc etc so I am just wondering what the state of play is now with the G9 - have the QC issues been sorted?
Any outstanding or new problems?
Thanks!
Only read same as I posted above so no clue, I was a 32" G7 owner so would be wanting another 1440p but with a Hardware G-Sync Module which IMO would solved the issues Samsung have with a lot of their monitors due to their Scalers.
They will probably call the above a G8 IMO.
I have a Hardware Moule G-Sync Monitor (have had them since 2013) it does not got a fan as not the newer 4k or High HZ models now called G-Sync Ultimate.
I've had the G9 since November and (touch wood) had none of the major issues that have been documented.
It's bolted to my simrig and mainly play Dirt Rally 2.0, iracing and AC. The whole rig can shake around at times, so it gets a far more rigorous work out than sitting on a desktop.
The only thing I have noticed is in the pause screen of Dirt Rally 2.0 there's a weird flickering graphical glitch on the middle left of the screen. It doesn't show up when recording in OBS, or any other time/game. Could possibly be the DP cable as I've had a few of those fail.
Is there any difference between the 49" 120hz and 240hz other than refresh rate? I'm mostly simming so the refresh rates isn't an issue for me.
I'm on my second G9 now after the buttons failed on the first one, luckily within a month. This one doesnt seem to wake properly with my RTX2070 and doesn't auto select the source either. Has any one got a solution to the wake issue.
I don't think you can revert after you have upgraded to 1009.3Hy, My G7 27" is update firmware 1009.3 in yesterday.. My question What the method downgrade firmware to older? I tried rename name file M-T7700CCAA-0000.0 not sucess .
